Updated on 2026-01-16 GMT+08:00
Configuring CORS
To use the OBS BrowserJS SDK to access a bucket, you must configure cross-origin resource sharing (CORS) for the bucket. The following configuration is recommended for the CORS rule.
Value
Allowed Origin
Allows all request origins.
You can also configure a domain name or IP address.
Allowed Method
PUT, GET, POST, DELETE, and HEAD
Allows all HTTP methods.
Allowed Header
Allows requests to carry any headers.
Expose Header
  • ETag
  • x-obs-request-id
  • x-obs-api
  • Content-Type
  • Content-Length
  • Cache-Control
  • Content-Disposition
  • Content-Encoding
  • Content-Language
  • Expires
  • x-obs-id-2
  • x-reserved-indicator
  • x-obs-version-id
  • x-obs-copy-source-version-id
  • x-obs-storage-class
  • x-obs-delete-marker
  • x-obs-expiration
  • x-obs-website-redirect-location
  • x-obs-restore
  • x-obs-version
  • x-obs-object-type
  • x-obs-next-append-position
Allows the response to return the specified additional headers.
NOTICE:
This parameter specifies the additional headers that a browser can expose to the client.
Take ETag as an example. It is not a standard response header, so to obtain its value, you need to add it in this parameter for the browser to return the value in the response.
