Does the SDK Support Uploading, Downloading, or Copying Objects in a Batch?
No.
Currently, the SDK does not provide such APIs. You need to encapsulate the service codes for uploading, downloading, or copying objects in a batch by yourself. The procedure is as follows:
- Invoke listObjects to list all objects to be uploaded, downloaded, or copied. For details about the code example, see Listing Objects.
- Invokes the API for uploading, downloading, or copying a single object for the listed objects.
The example code for uploading objects in a batch is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Define the prefix of objects in a bucket. final String objectPre = "object/"; // Folder to be uploaded. An example of the folder path is /storage/emulated/0/Pictures. Ensure that the files to be uploaded in the folder meet expectations. // Example of obtaining the path: final String localDirPath = Environment.getExternalStorageDirectory().getAbsolutePath() + "/Picture"; final String localDirPath = Environment.getExternalStorageDirectory().getAbsolutePath() + "localDirPath"; final List<File> list = new ArrayList<>(); public void uploadFiles() { // Traverse the folder to be uploaded and obtain all objects to be uploaded. File file = new File(localDirPath); listFiles(file); // Create an ObsClient instance. final ObsClient obsClient = new ObsClient(ak, sk, endPoint); // Initialize the thread pool. ExecutorService executorService = Executors.newFixedThreadPool(20); // Concurrently upload parts. for (File f : list) { executorService.execute(() -> { if (f.isDirectory()) { // For empty folders, create empty folder objects in the bucket. String remoteObjectKey = objectPre + f.getPath().substring(localDirPath.length() + 1) + "/"; obsClient.putObject(bucketName, remoteObjectKey, new ByteArrayInputStream(new byte[0])); } else { String remoteObjectKey = objectPre + f.getPath().substring(localDirPath.length() + 1); obsClient.putObject(bucketName, remoteObjectKey, new File(f.getPath())); } }); } // Wait until the upload is complete. executorService.shutdown(); while (!executorService.isTerminated()) { try { executorService.awaitTermination(5, TimeUnit.SECONDS); } catch (InterruptedException e) { e.printStackTrace(); } } // Close obsClient. try { obsClient.close(); } catch (IOException e) { e.printStackTrace(); } } // Scan all objects in the folder. void listFiles(File file) { File[] fs = file.listFiles(); assert fs != null; if (fs.length < 1) { // If uploading an empty folder is required, add it to the list. list.add(file); } else { for (File f : fs) { if (f.isDirectory()) { listFiles(f); } if (f.isFile()) { // Add objects to be uploaded to the list. list.add(f); } } } }
You can use multiple threads to concurrently upload, download, and copy data to improve efficiency.
