OBS Server-Side Error Codes
If the OBS server encounters an error when processing a request, a response containing the error code and error description is returned. The following table lists details about each error code and HTTP status code.
| Error Code | Description | HTTP Status Code |
| AccessDenied | Access denied. | 403 Forbidden |
| AccessForbidden | Insufficient permission. | 403 Forbidden |
| AccountProblem | Your account is abnormal (for example, being expired or frozen). | 403 Forbidden |
| AllAccessDisabled | You have no permission to perform the operation. | 403 Forbidden |
| AmbiguousGrantByEmailAddress | The provided email address is associated with more than one account. | 400 Bad Request |
| BadDigest | The specified value of Content-MD5 does not match the value received by OBS. | 400 Bad Request |
| BadDomainName | Invalid domain name. | 400 Bad Request |
| BadRequest | Invalid request parameters. | 400 Bad Request |
| BucketAlreadyExists | The requested bucket name already exists. The bucket namespace is shared by all users of OBS. Try again with another bucket name. | 409 Conflict |
| BucketAlreadyOwnedByYou | Your previous request for creating the named bucket succeeded and you already own it. | 409 Conflict |
| BucketNotEmpty | The bucket that you tried to delete is not empty. | 409 Conflict |
| CredentialsNotSupported | This request does not support security credentials. | 400 Bad Request |
| CustomDomainAreadyExist | The configured domain already exists. | 400 Bad Request |
| CustomDomainNotExist | The domain to be operated does not exist. | 400 Bad Request |
| DeregisterUserId | The user has been deregistered. | 403 Forbidden |
| EntityTooSmall | The size of the object to upload is smaller than the lower limit. | 400 Bad Request |
| EntityTooLarge | The size of the object to upload is larger than the upper limit. | 400 Bad Request |
| FrozenUserId | The user has been frozen. | 403 Forbidden |
| IllegalVersioningConfiguration Exception | Invalid versioning configuration in the request. | 400 Bad Request |
| IllegalLocationConstraintException | The configured region limitation is inconsistent with the region where it resides. | 400 Bad Request |
| InArrearOrInsufficientBalance | The user has no permission to perform some operations due to being in arrears or insufficient balance. | 403 Forbidden |
| IncompleteBody | Incomplete request body. | 400 Bad Request |
| IncorrectNumberOfFilesInPost Request | Each POST request must contain one file to upload. | 400 Bad Request |
| InlineDataTooLarge | The length of inline data exceeds the upper limit. | 400 Bad Request |
| InsufficientStorageSpace | Insufficient storage space. | 403 Forbidden |
| InternalError | Internal error. Please try again later. | 500 Internal Server Error |
| InvalidAccessKeyId | The access key ID provided by the customer does not exist in the system. | 403 Forbidden |
| InvalidAddressingHeader | The anonymous role must be specified. | N/A |
| InvalidArgument | Invalid parameter. | 400 Bad Request |
| InvalidBucketName | The specified bucket name in the request is invalid. | 400 Bad Request |
| InvalidBucket | The bucket to be accessed does not exist. | 400 Bad Request |
| InvalidBucketState | Invalid bucket status. | 409 Conflict |
| InvalidBucketStoragePolicy | An invalid new policy is specified during bucket policy modification. | 400 Bad Request |
| InvalidDigest | The Content-MD5 value specified in the HTTP header is invalid. | 400 Bad Request |
| InvalidEncryptionAlgorithmError | Incorrect encryption algorithm. | 400 Bad Request |
| InvalidLocationConstraint | The location specified during bucket creation is invalid. | 400 Bad Request |
| InvalidPart | One or more specified parts are not found. The parts may not be uploaded or the specified entity tags (ETags) do not match the parts' ETags. | 400 Bad Request |
| InvalidPartOrder | Parts are not listed in ascending order by part number. | 400 Bad Request |
| InvalidPayer | All access to this object has been disabled. | 403 Forbidden |
| InvalidPolicyDocument | The content of the form does not meet the conditions specified in the policy document. | 400 Bad Request |
| InvalidRange | The requested range cannot be obtained. | 416 Client Requested Range Not Satisfiable |
| InvalidRedirectLocation | Invalid redirect location. | 400 Bad Request |
| InvalidRequest | Invalid request. | 400 Bad Request |
| InvalidRequestBody | Invalid POST request body. | 400 Bad Request |
| InvalidSecurity | Invalid security credentials. | 403 Forbidden |
| InvalidStorageClass | Invalid storage class. | 400 Bad Request |
| InvalidTargetBucketForLogging | The delivery group has no ACL permission for the target bucket. | 400 Bad Request |
| InvalidURI | The specified URI cannot be resolved. | 400 Bad Request |
| KeyTooLong | The provided key is too long. | 400 Bad Request |
| MalformedACLError | The provided XML file has syntax errors or does not meet the format requirements. | 400 Bad Request |
| MalformedError | The XML format in the request is incorrect. | 400 Bad Request |
| MalformedLoggingStatus | The XML format of Logging is incorrect. | 400 Bad Request |
| MalformedPolicy | The bucket policy does not pass. | 400 Bad Request |
| MalformedPOSTRequest | The body of the POST request is in an incorrect format. | 400 Bad Request |
| MalformedQuotaError | The Quota XML format is incorrect. | 400 Bad Request |
| MalformedXML | This error code is returned after you send an XML file in incorrect format. The error message states: "The XML you provided was not well-formed or did not validate against our published schema." | 400 Bad Request |
| MaxMessageLengthExceeded | The request is too long. | 400 Bad Request |
| MaxPostPreDataLengthExceeded Error | The POST request fields prior to the file to upload are too large. | 400 Bad Request |
| MetadataTooLarge | The size of the metadata header exceeds the upper limit. | 400 Bad Request |
| MethodNotAllowed | The specified method is not allowed against the requested resource. The message "Specified method is not supported." is returned. | 405 Method Not Allowed |
| MissingContentLength | The HTTP header Content-Length is not provided. | 411 Length Required |
| MissingRegion | The region information is missing in the request, and the default region is required in the system. | 400 Bad Request |
| MissingRequestBodyError | This error code is returned after you send an empty XML file. The error message states: "Request body is empty." | 400 Bad Request |
| MissingRequiredHeader | Required headers are missing in the request. | 400 Bad Request |
| MissingSecurityHeader | A required header is missing in the request. | 400 Bad Request |
| NoSuchBucket | The bucket does not exist. | 404 Not Found |
| NoSuchBucketPolicy | No bucket policy exists. | 404 Not Found |
| NoSuchCORSConfiguration | No CORS configuration exists. | 404 Not Found |
| NoSuchCustomDomain | The requested user domain does not exist. | 404 Not Found |
| NoSuchKey | The key does not exist. | 404 Not Found |
| NoSuchLifecycleConfiguration | The requested lifecycle rule does not exist. | 404 Not Found |
| NoSuchPolicy | The policy name does not exist. | 404 Not Found |
| NoSuchUpload | The multipart upload does not exist. The upload ID does not exist or the multipart upload has been aborted or completed. | 404 Not Found |
| NoSuchVersion | The specified version ID does not match any existing version. | 404 Not Found |
| NoSuchWebsiteConfiguration | The requested website does not exist. | 404 Not Found |
| NotImplemented | The provided header implies a function that is unavailable. | 501 Not Implemented |
| NotSignedUp | Your account is not signed up in the system. Sign up the account before use. | 403 Forbidden |
| OperationAborted | A conflicting operation is being performed on this resource. Try again later. | 409 Conflict |
| PermanentRedirect | The requested bucket has been permanently redirected to a new URL. All future requests must be sent to the new URL. | 301 Moved Permanently |
| PreconditionFailed | At least one of the specified preconditions is not met. | 412 Precondition Failed |
| Redirect | The request is temporarily redirected. | 307 Moved Temporarily |
| RequestIsNotMultiPartContent | A bucket POST request must contain an enclosure-type multipart or the form-data. | 400 Bad Request |
| RequestTimeout | No read or write operation has been performed within the timeout period of the socket connection between the user and the server. | 400 Bad Request |
| RequestTimeTooSkewed | The request time and the server's time differ a lot. | 403 Forbidden |
| RequestTorrentOfBucketError | Requesting the bucket's torrent file is not allowed. | 400 Bad Request |
| ServiceNotImplemented | The request method is not implemented by the server. | 501 Not Implemented |
| ServiceNotSupported | The request method is not supported by the server. | 409 Conflict |
| ServiceUnavailable | The server is overloaded or has internal errors. | 503 Service Unavailable |
| SignatureDoesNotMatch | The provided signature does not match the signature calculated by OBS. Check your AK and SK and signature calculation method. | 403 Forbidden |
| SlowDown | Too frequent requests. Reduce your request frequency. | 503 Service Unavailable |
| System Capacity Not enough | Insufficient system space. | 403 Forbidden |
| TooManyCustomDomains | Too many user domains are configured. | 400 Bad Request |
| TemporaryRedirect | The request is redirected to the bucket while the domain name server (DNS) is being updated. | 307 Moved Temporarily |
| TooManyBuckets | You have attempted to create more buckets than allowed. | 400 Bad Request |
| TooManyObjectCopied | The number of copies of a single object exceeds the upper limit. | 400 Bad Request |
| TooManyWrongSignature | The request is rejected due to high-frequency errors. | 400 Bad Request |
| UnexpectedContent | This request does not support fields with content. | 400 Bad Request |
| UnresolvableGrantByEmailAddress | The provided email address does not match any recorded accounts. | 400 Bad Request |
| UserKeyMustBeSpecified | The user's AK is not carried in the request. | 400 Bad Request |
| WebsiteRedirect | The website request lacks bucketName. | 301 Moved Permanently |
| RestoreAlreadyInProgress | The Archive object is being restored. The request conflicts with another one. | 409 Conflict |
| ObjectHasAlreadyRestored | The objects have been restored and the retention period of the objects cannot be shortened. | 409 Conflict |
| InvalidObjectState | 403 Forbidden |
