Help Center/ Object Storage Service/ Android SDK Developer Guide (Ally Region)/ Access Logging/ Disabling Bucket Logging
Updated on 2026-01-16 GMT+08:00
To disable logging for a bucket is to call ObsClient.setBucketLogging to delete the logging configuration.
This example disables logging for bucket bucketname.
The example code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an instance of ObsClient. ObsClient obsClient = new ObsClient(ak, sk, endPoint); // Leave the logging settings in blank. obsClient.setBucketLogging("bucketname", new BucketLoggingConfiguration());
Parent topic: Access Logging
