Updated on 2026-01-16 GMT+08:00
Viewing CORS Rules
You can call ObsClient.getBucketCors to view CORS rules of a bucket.
This example views the CORS rule of bucket bucketname.
The example code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console.
String endPoint = "https://your-endpoint";
// Create an instance of ObsClient.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
BucketCors cors = obsClient.getBucketCors("bucketname");
for(BucketCorsRule rule : cors.getRules()){
    Log.i("GetBucketCors","\t" + rule.getId());
    Log.i("GetBucketCors","\t" + rule.getMaxAgeSecond());
    Log.i("GetBucketCors","\t" + rule.getAllowedHeader());
    Log.i("GetBucketCors","\t" + rule.getAllowedOrigin());
    Log.i("GetBucketCors","\t" + rule.getAllowedMethod());
    Log.i("GetBucketCors","\t" + rule.getExposeHeader());
