Help Center/ Object Storage Service/ Android SDK Developer Guide (Ally Region)/ Versioning Management/ Setting Versioning Status for a Bucket
Updated on 2026-01-16 GMT+08:00
You can call ObsClient.setBucketVersioning to set the versioning status for a bucket. OBS supports two versioning statuses.
| Versioning Status | Description | Value in OBS Android SDK |
| Enabled |
| VersioningStatusEnum.ENABLED |
| Suspended |
| VersioningStatusEnum.SUSPENDED |
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an instance of ObsClient. ObsClient obsClient = new ObsClient(ak, sk, endPoint); // Enable versioning. obsClient.setBucketVersioning("bucketname", new BucketVersioningConfiguration(VersioningStatusEnum.ENABLED)); // Suspend versioning. obsClient.setBucketVersioning("bucketname", new BucketVersioningConfiguration(VersioningStatusEnum.SUSPENDED));
Parent topic: Versioning Management
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
