Updated on 2026-01-16 GMT+08:00
Obtaining Object Attributes
You can call ObsClient.getObjectMetadata to obtain attributes of an object, including the length, MIME type, and custom metadata. Sample code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console.
String endPoint = "https://your-endpoint";
// Create an ObsClient instance.
final ObsClient obsClient = new ObsClient(ak, sk, endPoint);
ObjectMetadata metadata = obsClient.getObjectMetadata("bucketname", "objectname");
Log.i("GetObjectMetadata","\t" + metadata.getContentType());
Log.i("GetObjectMetadata","\t" + metadata.getContentLength());
// Obtain custom metadata.
Log.i("GetObjectMetadata","\t" + metadata.getUserMetadata("property"));
// Obtain all original response headers.
Log.i("GetObjectMetadata","\t" + metadata.getOriginalHeaders());
  • Due to HTTP coding restrictions, non-ASCII characters cannot be sent. The SDK will decode the information in response headers using URL decoding rules.
  • If you do not need the SDK to decode for you, call GetObjectMetadataRequest.setIsEncodeHeaders(false) to disable auto decoding.
  • You can also call metadata.getOriginalHeaders to obtain information about all original response headers.
