Updated on 2026-01-16 GMT+08:00
Rewriting Response Headers
When downloading an object, you can rewrite some HTTP/HTTPS response headers. The following table lists rewritable response headers.
Method in OBS Android SDK
contentType
Rewrites Content-Type in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setContentType
contentLanguage
Rewrites Content-Language in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setContentLanguage
expires
Rewrites Expires in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setExpires
cacheControl
Rewrites Cache-Control in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setCacheControl
contentDisposition
Rewrites Content-Disposition in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setContentDisposition
contentEncoding
Rewrites Content-Encoding in HTTP/HTTPS responses.
ObjectRepleaceMetadata.setContentEncoding
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console.
String endPoint = "https://your-endpoint";
// Create an instance of ObsClient.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
GetObjectRequest request = new GetObjectRequest("bucketname", "objectname");
ObjectRepleaceMetadata replaceMetadata = new ObjectRepleaceMetadata();
replaceMetadata.setContentType("image/jpeg");
request.setReplaceMetadata(replaceMetadata);
ObsObject obsObject = obsClient.getObject(request);
Log.i("GetObject", object.getMetadata().getContentType());
obsObject.getObjectContent().close();
