Managing Bucket ACLs
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources.
- Specify a pre-defined ACL when creating a bucket.
- Call ObsClient.setBucketAcl to specify a pre-defined ACL.
- Call ObsClient.setBucketAcl to specify a user-defined ACL.
OBS supports five types of bucket or object ACL configuration items, as listed in the following table:
| Permission | Description | Value in OBS Android SDK |
| READ | A grantee with this permission for a bucket can obtain the list of objects in and metadata of the bucket. A grantee with this permission for an object can obtain the object content and metadata. | Permission.PERMISSION_READ |
| WRITE | A grantee with this permission for a bucket can upload, overwrite, and delete any object in the bucket. This permission is not applicable to objects. | Permission.PERMISSION_WRITE |
| READ_ACP | A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission permanently. | Permission.PERMISSION_READ_ACP |
| WRITE_ACP | A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission permanently. A grantee with this permission can modify the access control policy and thus the grantee obtains full access permissions. | Permission.PERMISSION_WRITE_ACP |
| FULL_CONTROL | A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket. A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object. | Permission.PERMISSION_FULL_CONTROL |
There are five access control policies pre-defined in OBS, as described in the following table:
| Policy | Description | Value in OBS Android SDK |
| private | The owner of a bucket or object has the FULL_CONTROL permission for the bucket or object. Other users have no permission to access the bucket or object. | AccessControlList.REST_CANNED_PRIVATE |
| public-read | If this permission is set for a bucket, everyone can obtain the list of objects, multipart uploads, and object versions in the bucket, as well as metadata of the bucket. If this permission is set for an object, everyone can obtain the content and metadata of the object. | AccessControlList.REST_CANNED_PUBLIC_READ |
| public-read-write | If this permission is set for a bucket, everyone can obtain the object list in the bucket, multipart uploads in the bucket, metadata of the bucket; upload objects; delete objects; initialize multipart uploads; upload parts; combine parts; copy parts; and abort multipart uploads. If this permission is set for an object, everyone can obtain the content and metadata of the object. | AccessControlList.REST_CANNED_PUBLIC_READ_WRITE |
| public-read-delivered | If this permission is set for a bucket, everyone can obtain the object list, multipart uploads, and bucket metadata in the bucket, and obtain the content and metadata of the objects in the bucket. This permission cannot be set for objects. | AccessControlList.REST_CANNED_PUBLIC_READ_DELIVERED |
| public-read-write-delivered | If this permission is set for a bucket, everyone can obtain the object list in the bucket, multipart uploads in the bucket, metadata of the bucket; upload objects; delete objects; initialize multipart uploads; upload parts; combine parts; copy parts; abort multipart uploads; and obtain content and metadata of objects in the bucket. This permission cannot be set for objects. | AccessControlList.REST_CANNED_PUBLIC_READ_WRITE_DELIVERED |
Specifying a Pre-defined ACL During Bucket Creation
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an ObsClient instance. ObsClient obsClient = new ObsClient(ak, sk, endPoint); ObsBucket obsBucket = new ObsBucket(); obsBucket.setBucketName("bucketname"); // Set the ACL to public read and write. obsBucket.setAcl(AccessControlList.REST_CANNED_PUBLIC_READ_WRITE); // Create a bucket. obsClient.createBucket(obsBucket);
Setting a Pre-defined ACL for a Bucket
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an ObsClient instance. ObsClient obsClient = new ObsClient(ak, sk, endPoint); // Set the bucket ACL to private read and write. obsClient.setBucketAcl("bucketname", AccessControlList.REST_CANNED_PRIVATE);
Setting a User-defined Bucket ACL
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an ObsClient instance. ObsClient obsClient = new ObsClient(ak, sk, endPoint); AccessControlList acl = new AccessControlList(); Owner owner = new Owner(); owner.setId("ownerid"); acl.setOwner(owner); // Grant the FULL_CONTROL permission to a specified user. acl.grantPermission(new CanonicalGrantee("userid"), Permission.PERMISSION_FULL_CONTROL); // Grant the READ permission to all users. acl.grantPermission(GroupGrantee.ALL_USERS, Permission.PERMISSION_READ); // Set the bucket ACL. obsClient.setBucketAcl("bucketname", acl);
The owner or grantee ID needed in the ACL indicates the account ID, which can be viewed on the My Credentials page of OBS Console.
Obtaining a Bucket ACL
You can call ObsClient.getBucketAcl to obtain a bucket ACL. Sample code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an ObsClient instance. ObsClient obsClient = new ObsClient(ak, sk, endPoint); AccessControlList acl = obsClient.getBucketAcl("bucketname"); Log.i("GetBucketAcl", acl.toString());
