Help Center/ Object Storage Service/ Android SDK Developer Guide (Ally Region)/ Bucket Management/ Deleting a Bucket
Updated on 2026-01-16 GMT+08:00
Deleting a Bucket
You can call ObsClient.deleteBucket to delete a bucket. Sample code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an instance of ObsClient. ObsClient obsClient = new ObsClient(ak, sk, endPoint); // Delete a bucket. obsClient.deleteBucket("bucketname");
- Only empty buckets (without objects and part fragments) can be deleted.
- Bucket deletion is a non-idempotence operation and an error will be reported if the to-be-deleted bucket does not exist.
Parent topic: Bucket Management
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
