Help Center/ Object Storage Service/ Android SDK Developer Guide (Ally Region)/ Quick Start/ Downloading an Object
Updated on 2026-01-16 GMT+08:00
This example downloads object objectname from bucket bucketname.
The example code is as follows:
ObsObject obsObject = obsClient.getObject("bucketname", "objectname"); InputStream content = obsObject.getObjectContent(); if (content != null) { BufferedReader reader = new BufferedReader(new InputStreamReader(content)); while (true) { String line = reader.readLine(); if (line == null) break; Log.i("GetObject", "\n" + line); } reader.close(); }
- When you call ObsClient.getObject, an instance of ObsObject will be returned. This instance contains the content and properties of the object.
- When you call ObsObject.getObjectContent to obtain an object input stream, you can read the input stream to obtain its contents. Close the input stream after use.
- For more information, see Object Download Overview.
Parent topic: Quick Start
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
