Updated on 2026-01-16 GMT+08:00
Installing the SDK
Download Address
- Latest version of OBS Android SDK: Download
Compatibility
- Recommended Android versions: Android 7.0, 8.0, 8.1, 9.0, and 10.0 (HTTP/HTTPS)
- If you are using the JDK 1.8 environment, version 3.21.12 is recommended for OBS Android SDK.
- Namespace: Compatible with earlier versions (2.1.x). All external APIs are contained in the com.obs.services, com.obs.services.model, and com.obs.services.exception packages.
- API functions: Compatible with earlier versions (2.1.x).
If Android 4.4 or an earlier version is used, configure HTTP to access OBS.
ProGuard
#okhttp
-dontwarn okhttp3.**
-keep class okhttp3.**{*;}
#okio
-dontwarn okio.**
-keep class okio.**{*;}
#sdk
-keep class com.obs.services.** {*;}
-keep class com.obs.log.** {*;}
#java-xmlbuilder
-keep class com.jamesmurty.utils.**{*;} Feedback
