Ports Supported by WAF
WAF can protect standard and non-standard ports. When you add a website to WAF, you need to specify protection port, which is your service port. WAF will then forward and protect traffic over this port. This section describes the standard and non-standard ports WAF can protect.
Deployment Mode |
Port Type |
HTTP |
HTTPS |
Port Limit |
Cloud mode |
Standard ports |
80 |
443 |
Unlimited |
Non-standard ports (86 in total) |
81, 82, 83, 84, 86, 87, 88, 89, 800, 808, 5000, 8000, 8001, 8002, 8003, 8008, 8009, 8010, 8020, 8021, 8022, 8025, 8026, 8077, 8078, 8080, 8085, 8086, 8087, 8088, 8089, 8090, 8091, 8092, 8093, 8094, 8095, 8096, 8097, 8098, 8106, 8118, 8181, 8334, 8336, 8800, 8686, 8888, 8889, 8999, 8011, 8012, 8013, 8014, 8015, 8016, 8017, and 8070 |
4443, 5443, 6443, 7443, 8081, 8082, 8083, 8084, 8443, 8843, 9443, 8553, 8663, 9553, 9663, 18110, 18381, 18980, 28443, 18443, 8033, 18000, 19000, 7072, 7073, 8803, 8804, and 8805 |
20 |
Dedicated mode |
Standard ports |
80 |
443 |
Unlimited |
Non-standard ports (182 in total) |
9945, 9770, 81, 82, 83, 84, 88, 89, 800, 808, 1000, 1090, 3128, 3333, 3501, 3601, 4444, 5000, 5222, 5555, 5601, 6001, 6666, 6788, 6789, 6842, 6868, 7000, 7001, 7002, 7003, 7004, 7005, 7006, 7009, 7010, 7011, 7012, 7013, 7014, 7015, 7016, 7018, 7019, 7020, 7021, 7022, 7023, 7024, 7025, 7026, 7070, 7081, 7082, 7083, 7088, 7097, 7777, 7800, 7979, 8000, 8001, 8002, 8003, 8008, 8009, 8010, 8020, 8021, 8022, 8025, 8026, 8077, 8078, 8080, 8085, 8086, 8087, 8088, 8089, 8090, 8091, 8092, 8093, 8094, 8095, 8096, 8097, 8098, 8106, 8118, 8181, 8334, 8336, 8800, 8686, 8888, 8889, 8989, 8999, 9000, 9001, 9002, 9003, 9080, 9200, 9802, 10000, 10001, 10080, 12601, 86, 9021, 9023, 9027, 9037, 9081, 9082, 9201, 9205, 9207, 9208, 9209, 9210, 9211, 9212, 9213, 48800, 87, 97, 7510, 9180, 9898, 9908, 9916, 9918, 9919, 9928, 9929, 9939, 28080, 33702, 8011, 8012, 8013, 8014, 8015, 8016, 8017, and 8070 |
8750, 8445, 18010, 4443, 5443, 6443, 7443, 8081, 8082, 8083, 8084, 8443, 8843, 9443, 8553, 8663, 9553, 9663, 18110, 18381, 18980, 28443, 18443, 8033, 18000, 19000, 7072, 7073, 8803, 8804, 8805, and 9999 |
Unlimited |
