Edition Differences
WAF provides cloud and dedicated modes for you to deploy WAF instances. For more details, see Cloud and Dedicated WAF Modes.
You can select the cloud WAF and/or dedicated WAF instances to meet your business needs. For their differences, see Table 1. Figure 1 shows deployment architectures.
Item |
Cloud Mode |
Dedicated mode |
Billing mode |
Pay-per-use |
Pay-per-use |
Application scenarios |
Service servers are deployed on a cloud or in on-premises data centers. |
Service servers are deployed on the cloud. Dedicated WAF instances are suitable large enterprise websites that have a large service scale and have customized security requirements. |
Protected objects |
Domain names |
Advantages |
Specifications Supported by Each Edition
Service Scale |
Cloud Mode |
Dedicated Mode |
Peak rate of normal service requests |
The following lists the specifications of a single instance.
NOTICE:
Maximum QPS values are for reference only. They may vary depending on your businesses. The real-world QPS is related to the request size and the type and quantity of protection rules you customize. |
Service bandwidth threshold (Origin servers are deployed on the cloud.) |
Number of domain names |
30 (Supports three top-level domain names.) |
2,000 (Supports 2,000 top-level domain names) |
Back-to-source IP address quantity (the number of WAF back-to-source IP addresses that can be allowed by a protected domain name) |
20 |
N/A |
Quantity of supported ports |
N/A |
Peak rate of CC attack protection |
N/A |
CC attack protection rules |
200 |
100 |
Precise protection rules |
1,000 |
100 |
Reference table rules |
1,000 |
100 |
IP address blacklist and whitelist rules |
2,000 |
100 |
Geolocation access control rules |
200 |
100 |
Web tamper protection rules |
200 |
100 |
Information leakage prevention rules |
200 |
100 |
Global protection whitelist rules |
2,000 |
1,000 |
Data masking rules |
200 |
100 |
