Configuration Example: Adding a Domain Name to WAF
When adding a domain name to WAF, the configurations are slightly different based on the service scenarios.
- Example 1: Protecting Traffic to the Same Standard Port with Different Origin Server IP Addresses Assigned
- Example 2: Protecting Traffic to a Non-Standard Port with Different Origin Server IP Addresses Assigned
- Example 3: Protecting Different Service Ports
- Example 4: Configuring Protocols for Different Access Methods
- Select Standard port from the Protected Port drop-down list.
- Select HTTP or HTTPS for Client Protocol. Figure 1 and Figure 2 show standard port configurations when the client protocol is HTTP or HTTPS.
If Client Protocol is set to HTTPS, a certificate is required.
- Your website visitors can access the website without adding a port to the end of the domain name. For example, enter http://www.example.com in the address box of the browser to access the website.
- In the Protected Port drop-down list, select a non-standard port you want to protect.
- Select HTTP or HTTPS for Client Protocol for all server ports. Figure 3 and Figure 4 show the configuration of non-standard HTTP or HTTPS port, respectively.
- Visitors must add the configured non-standard port to the domain name when they access your website. Otherwise, error 404 is returned. If the non-standard port is 8080, enter http://www.example.com:8080 in the address box of the browser.
WAF provides various protocol types. If your website is www.example.com, WAF provides the following four access modes:
- HTTP mode
Figure 7 HTTP mode
This configuration allows web visitors to access http://www.example.com over HTTP only. If they access it over HTTPS, they will receive the 302 Found code and be redirected to http://www.example.com.
- HTTPS method. This configuration allows web visitors to access your website over HTTPS only. If they access it over HTTP, they are redirected to the HTTPS URL.
Figure 8 HTTPS redirection
- If web visitors access your website over HTTPS, the website returns a successful response.
- If web visitors access http://www.example.com over HTTP, they will receive the 301 Found code and are directed to https://www.example.com.
- HTTP/HTTPS forwarding method
Figure 9 HTTP and HTTPS forwarding
- If web visitors access your website over HTTP, the website returns a successful response but no communication between the browser and website is encrypted.
- If web visitors access your website over HTTPS, the website returns a successful response and all communications between the browser and website are encrypted.
- HTTPS offloading by WAF
Figure 10 HTTPS offloading
If web visitors access your website over HTTPS, WAF forwards the requests to your origin server over HTTP.
