Modifying or Deleting a Blacklist or Whitelist IP Address Group
This topic describes how to modify or delete an IP address group.
Only address groups not used by any rules can be deleted. Before you delete an address group that is being used by a blacklist or whitelist rule, remove the address group from the rule first.
- Click
in the upper left corner of the management console and select a region or project. - Click
in the upper left corner of the page and choose . - In the navigation pane on the left, choose Objects > Address Groups.
- In the address group list, view the address group information.
Table 1 Parameter description Parameter
Group Name
Address group name you configured.
IP Address/Range
IP addresses or IP address ranges added to the address group.
Rule
Rules that are using the address group.
Remarks
Supplementary information about the address group.
- Modify or delete an IP address group.
- Modify an address group.
In the row containing the address group you want to modify, click Modify in the Operation column. In the Modify Address Group dialog box, change the group name or IP address/IP address range, and click Confirm.
- Delete an address group.
In the row containing the address group you want to delete, click Delete in the Operation column. In the displayed dialog box, click OK.
