Certificate Management
This topic lists some frequently asked questions (FAQs) about how to use a certificate.
How Do I Select a Certificate When Configuring a Wildcard Domain Name?
Each domain name must correspond to a certificate. A wildcard domain name can only be used for a wildcard domain certificate. If you only have single-domain certificates, you need to add domain names one by one in WAF.
Do I Need to Import the Certificates That Have Been Uploaded to ELB to WAF?
You can select a created certificate or import a new certificate. You need to import the certificate that has been uploaded to ELB to WAF.
How Do I Convert a Certificate into PEM Format?
Format |
Conversion Method |
CER/CRT |
Rename the cert.crt certificate file to cert.pem. |
PFX |
P7B |
DER |
- Before running an OpenSSL command, ensure that the OpenSSL tool has been installed on the local host.
- If your local PC runs a Windows operating system, go to the command line interface (CLI) and then run the certificate conversion command.
