- What's New
- Function Overview
Product Bulletin
- Java Spring Framework Remote Code Execution Vulnerability
- Apache Dubbo Deserialization Vulnerability
- DoS Vulnerability in the Open-Source Component Fastjson
- Remote Code Execution Vulnerability of Fastjson
- Oracle WebLogic wls9-async Deserialization Remote Command Execution Vulnerability (CNVD-C-2019-48814)
Billing
- WAF Billing Overview
- Billing Modes
- Billing Items
- Billing Examples
- Changing the Billing Mode
- Renewing Your Subscription
- Bills
- About Arrears
- Billing Termination
- Cost Management
Billing FAQs
- Can I Switch Between Yearly/Monthly and Pay-per-Use Payments for WAF?
- Can I Use WAF for Free?
- How Is WAF Billed?
- Can WAF Continue Protecting a Domain Name When It Expires?
- How Do I Unsubscribe from WAF?
- Can I Retain the Original Configurations When I Unsubscribe from a WAF Instance and Then Purchase Another One?
- How Do I Know When My WAF Expires?
- Getting Started
User Guide
- Creating a User Group and Granting Permissions
- Buying WAF
- Connecting a Website to WAF
- Viewing Protection Events
Configuring Protection Policies
- Protection Configuration Overview
- Configuring Basic Web Protection to Defend Against Common Web Attacks
- Configuring Intelligent Access Control Rules to Accurately Defend Against CC Attacks
- Configuring CC Attack Protection Rules to Defend Against CC Attacks
- Configuring Custom Precise Protection Rules
- Configuring IP Address Blacklist and Whitelist Rules to Block or Allow Specified IP Addresses
- Configuring Geolocation Access Control Rules to Block or Allow Requests from Specific Locations
- Configuring Threat Intelligence Access Control Rules to Block or Allow IP Addresses in a Specified IP Address Library
- Configuring Web Tamper Protection Rules to Prevent Static Web Pages from Being Tampered With
- Configuring Anti-Crawler Rules
- Configuring Information Leakage Prevention Rules to Protect Sensitive Information from Leakage
- Configuring a Global Protection Whitelist Rule to Ignore False Alarms
- Configuring Data Masking Rules to Prevent Privacy Information Leakage
- Configuring a Scanning Blocking Rule to Automatically Block Heavy-Traffic Attacks
- Creating a Reference Table to Configure Protection Metrics in Batches
- Configuring a Known Attack Source Rule to Block Specific Visitors for a Specified Duration
- Condition Field Description
- Application Types WAF Can Protect
- Viewing the Dashboard
Website Settings
Recommended Configurations After Website Connection
- Configuring PCI DSS/3DS Compliance Check and TLS
- Enabling WAF IPv6 Protection
- Enabling the HTTP/2 Protocol
- Configuring a Timeout for Connections Between WAF and a Website Server
- Enabling Break Protection to Protect Origin Servers
- Configuring a Traffic Identifier for a Known Attack Source
- Forwarding Custom Header Fields
- Modifying the Alarm Page
- Enabling the Cookie Security Attributes
Managing Websites
- Viewing Basic Information of a Website
- Exporting Website Settings
- Changing the Protection Mode
- Switching the Load Balancing Algorithm
- Changing the Protection Policy for a Protected Website
- Updating the Certificate Used for a Website
- Editing Server Information
- Viewing Protection Information About a Protected Website on Cloud Eye
- Migrating Domain Names to Other Enterprise Projects
- Deleting a Protected Website from WAF
- Policy Management
- Security Reports
- Object Management
- System Management
- Permissions Management
- Monitoring and Auditing
Best Practices
- WAF Best Practices You May Need
Website Access Configuration
- Connecting a Website Without a Proxy to WAF in CNAME Access Mode
- Combining AAD and WAF to Get All-Round Protection
- Combining CDN and WAF to Get Improved Protection and Load Speed
- Combining WAF and Layer-7 Load Balancers to Protect Services over Any Ports
- Using WAF, ELB, and NAT Gateway to Protect Services Not Deployed on Our Cloud
- Website Protection Configuration Suggestions
Mitigating Web Security Vulnerabilities
- Defending Against Challenge Collapsar (CC) Attacks
- Using WAF to Block Crawler Attacks
- Verifying a Global Protection Whitelist Rule by Simulating Requests with Postman
- Combining WAF and HSS to Improve Web Page Tampering Protection
- Configuring Header Field Forwarding to Disable Response Packet Compression
- Configuring Origin Server Security
- Using LTS to Analyze WAF Logs
- Obtaining the Real Client IP Addresses
- Configuring Alarms on Cloud Eye for Abnormal WAF Metrics
- Migrating Protection Policies for Your Website
API Reference
- Before You Start
- API Overview
- API Calling
APIs
Managing Websites Protected by Dedicated WAF Engines
- Querying the List of Domain Names Protected by Dedicated WAF Instances
- Adding a Domain Name to a Dedicated WAF Instance
- Modifying a Domain Name Protected by a Dedicated WAF Instance
- Querying Domain Name Settings in Dedicated Mode
- Deleting a Domain Name from a Dedicated WAF Instance
- Modifying the Protection Status of a Domain Name in Dedicated Mode
- Policy Management
Rule Management
- Changing the Status of a Rule
- Querying CC Attack Protection Rules
- Creating a CC Attack Protection Rule
- Querying a CC Attack Protection Rule by ID
- Updating a CC Attack Protection Rule
- Deleting a CC Attack Protection Rule
- Querying the List of Precise Protection Rules
- Creating a precise protection rule
- Querying a Precise Protection Rule by ID
- Updating a precise protection rule
- Deleting a precise protection rule
- Creating a Global Protection Whitelist (Formerly False Alarm Masking) Rule
- Querying the List of Global Protection Whitelist (Formerly False Alarm Masking) Rules
- Updating a Global Protection Whitelist (Formerly False Alarm Masking) Rule
- Deleting a Global Protection Whitelist (Formerly False Alarm Masking) Rule
- Querying the Blacklist and Whitelist Rule List
- Creating a Blacklist/Whitelist Rule
- Querying a blacklist or whitelist rule
- Updating a Blacklist or Whitelist Protection Rule
- Querying Global Protection Whitelist (Formerly False Alarm Masking) Rules
- Deleting a Blacklist or Whitelist Rule
- Querying the JavaScript Anti-Crawler Rule List
- Updating a JavaScript Anti-Crawler Protection Rule
- Creating a JavaScript Anti-Crawler Rule
- Querying a JavaScript Anti-Crawler Rule
- Updating a JavaScript Anti-Crawler Rule
- Deleting a JavaScript Anti-Crawler Rule
- Querying the list of Data Masking Rules.
- Creating a Data Masking Rule
- Querying a Data Masking Rule
- Updating a Data Masking Rule
- Deleting a Data Masking Rule
- Querying the List of Known Attack Source Rules
- Creating a Known Attack Source Rule
- Querying a Known Attack Source Rule by ID
- Updating a Known Attack Source Rule
- Deleting a Known Attack Source Rule
- Querying the List of Geolocation Access Control Rules
- Creating a Geolocation Access Control Rule
- Querying a Geolocation Access Control Rule by ID.
- Updating a Geolocation Access Control Rule
- Deleting a Geolocation Access Control Rule
- Querying the List of Web Tamper Protection Rules
- Creating a Web Tamper Protection Rule
- Querying a Web Tamper Protection Rule
- Deleting a Web Tamper Protection Rule
- Updating the Cache for a Web Tamper Protection Rule
- Querying the List of Information Leakage Prevention Rules
- Creating an Information Leakage Prevention Rule
- Querying an Information Leakage Prevention Rule
- Updating an Information Leakage Prevention Rule
- Deleting an Information Leakage Prevention Rule
- Querying the Reference Table List
- Querying a Reference Table
- Modifying a Reference Table
- Deleting a Reference Table
- Address Group Management
- Certificate Management
- Event Management
- Dashboard
- Dedicated Instance Management
- Log Reporting
- Managing Your Subscriptions
- Domain Name Management
- System Management
- Alarm Management
Protected Website Management in Cloud Mode
- Querying the List of Domain Names Protected in Cloud Mode
- Adding a Domain Name to the Cloud WAF
- Querying Details About a Domain Name by Domain Name ID in Cloud Mode
- Updating Configurations of Domain Names Protected with Cloud WAF
- Deleting a Domain Name from the Cloud WAF
- Changing the Protection Status of a Domain Name
- Obtaining Domain Name Routing Information (in Cloud Mode)
- Querying the Domain Name of a Tenant
- Querying Features Available at a Site
- Appendix
- SDK Reference
About WAF
- WAF Basics
- Can WAF Protect an IP Address?
- What Objects Does WAF Protect?
- Does WAF Block Customized POST Requests?
- Does WAF Protect Traffic from Both IPv4 and IPv6 Addresses?
- What Are the Differences Between the Web Tamper Protection Functions of WAF and HSS?
- Which Web Service Framework Protocols Does WAF Support?
- Can WAF Protect Websites Accessed Through HSTS or NTLM Authentication?
- What Are the Differences Between WAF Forwarding and Nginx Forwarding?
- What Are the Differences Between WAF and CFW?
- Can I Configure Session Cookies in WAF?
- How Does WAF Detect SQL Injection, XSS, and PHP Injection Attacks?
- Can WAF Defend Against the Apache Struts2 Remote Code Execution Vulnerability (CVE-2021-31805)?
- Why Does the Vulnerability Scanning Tool Report Disabled Non-standard Ports for My WAF-Protected Website?
- What Are the Restrictions on Using WAF in Enterprise Projects?
- What Are Local File Inclusion and Remote File Inclusion?
- What Is the Difference Between QPS and the Number of Requests?
- Does WAF Support Custom Authorization Policies?
- Why Do Cookies Contain the HWWAFSESID or HWWAFSESTIME field?
- Can I Switch Between the WAF Cloud Mode and Dedicated Mode?
- Can I Add a Domain Name or IP Address to WAF Under Different Accounts?
- What Are Regions and AZs?
- Can I Use WAF Across Regions?
- In Which Regions Is WAF Available?
- Can I Use WAF Across Enterprise Projects?
- Can I Use a WAF Instance in a Specific Enterprise Project for Other Enterprise Projects?
About Purchase and Specifications Change
- Can I Buy Multiple WAF Instances Using the Same Account?
- What Are the Differences Between the Permissions of an Account and Those of IAM Users?
- Can I Share My WAF with Other Accounts?
- How Does WAF Calculate Domain Name Quota Usage?
- Can I Add More Protection Rules?
- What Can I Do If the Website Traffic Exceeds the WAF Service Request Limit?
- What Are the Impacts When QPS Exceeds the Allowed Peak Rate?
- Can I Change WAF Specifications During Renewal?
- Where and When Can I Buy a Domain, QPS, or Rule Expansion Package?
- How Do I Select Service QPS When Purchasing WAF?
- Is Service QPS Calculated Based on Incoming Traffic or Outgoing Traffic?
- Does WAF Have a Limit on the Protection Bandwidth or Shared Bandwidth?
- Where Can I View the Inbound and Outbound Bandwidths of a Protected Website?
Website Connect Issues
- How Do I Configure Domain Names to Be Protected When Adding Domain Names?
- Do I Have to Configure the Same Port as That of the Origin Server When Adding a Website to WAF?
- How Do I Whitelist Back-to-Source IP Addresses of Cloud WAF?
- How Long Will CNAME Records Be Retained After I Delete a Domain Name from WAF?
- What Are the Precautions for Configuring Multiple Server Addresses for Backend Servers?
- Does WAF Support Wildcard Domain Names?
- Does WAF Protect Chinese Domain Names?
- How Does WAF Forward Access Requests When Both a Wildcard Domain Name and a Single Domain Name Are Connected to WAF?
- What Can I Do If the Message "Illegal server address" Is Displayed When I Add a Domain Name?
- Why Am I Seeing the "Someone else has already added this domain name. Please confirm that the domain name belongs to you" Error Message?
- Why Cannot I Select a Client Protocol When Adding a Domain Name?
- Can I Set the Origin Server Address to a CNAME Record If I Use Cloud WAF?
- How Do I Verify Domain Ownership Using Huawei Cloud DNS?
- What Are Impacts If No Subdomain Name and TXT Record Are Configured?
- How Do I Query a Domain Name Provider?
- What Are the Differences Between the Old and New CNAME Records?
- Can I Access a Website Using an IP Address After a Domain Name Is Connected to WAF?
- How Can I Forward Requests Directly to the Origin Server Without Passing Through WAF?
- Why Cannot the Protection Mode Be Enabled After a Domain Name Is Connected to WAF?
Protection Rules
- Which Protection Levels Can Be Set for Basic Web Protection?
- What Is the Peak Rate of CC Attack Protection?
- When Is Cookie Used to Identify Users?
- What Are the Differences Between Rate Limit and Allowable Frequency in a CC Rule?
- Why Cannot the Verification Code Be Refreshed When Verification Code Is Configured in a CC Attack Protection Rule?
- How Can I Allow Access from .js Files?
- Can I Batch Add IP Addresses to a Blacklist or Whitelist Rule?
- Can I Import or Export a Blacklist or Whitelist into or from WAF?
- Why Does a Requested Page Fail to Respond to the Client After the JavaScript-based Anti-Crawler Is Enabled?
- Is There Any Impact on Website Loading Speed If Other Crawler Check in Anti-Crawler Is Enabled?
- How Does JavaScript Anti-Crawler Detection Work?
- In Which Situations Will the WAF Policies Fail?
- How Do I Allow Requests from Only IP Addresses in a Specified Geographical Region?
- How Do I Allow Only Specified IP Addresses to Access Protected Websites?
- Which Protection Rules Are Included in the System-Generated Policy?
- Why Does the Page Fail to Be Refreshed After WTP Is Enabled?
- What Are the Differences Between Blacklist/Whitelist Rules and Precise Protection Rules on Blocking Access Requests from Specified IP Addresses?
- What Do I Do If a Scanner, such as AppScan, Detects that the Cookie Is Missing Secure or HttpOnly?
- How Do I Block Layer-4 IP Addresses?
- IPv6 Protection
Protection Event Logs
- Can WAF Log Protection Events?
- Can I Obtain WAF Logs Using APIs?
- How Do I Obtain Data about Block Actions?
- What Does "Mismatch" for "Protective Action" Mean in the Event List?
- How Does WAF Obtain the Real Client IP Address for a Request?
- Can WAF Logs Be Transferred to OBS?
- How Long Can WAF Protection Logs Be Stored?
- Can I Query Protection Events of a Batch of Specified IP Addresses at Once?
- Will WAF Record Unblocked Events?
- Why Is the Traffic Statistics on WAF Inconsistent with That on the Origin Server?
- Why Is the Number of Logs on the Dashboard Page Inconsistent with That on the Configure Logs Tab?
- Why Are There Garbled Characters in Event Data I Exported from WAF?
About WAF
Troubleshooting
- Troubleshooting Website Connection Exceptions
Troubleshooting Certificate and Cipher Suite Issues
- How Do I Fix an Incomplete Certificate Chain?
- Why Does My Certificate Not Match the Key?
- Why Are HTTPS Requests Denied on Some Mobile Phones?
- What Do I Do If the Protocol Is Not Supported and the Client and Server Do Not Support Common SSL Protocol Versions or Cipher Suites?
- Why Is the Bar Mitzvah Attack on SSL/TLS Detected?
Troubleshooting Traffic Forwarding Exceptions
- How Do I Troubleshoot 404/502/504 Errors?
- Why Am I Seeing Error Code 418?
- Why Am I Seeing Error Code 523?
- Why Was My Website Redirected So Many Times?
- Why Am I Seeing Error Code 414 Request-URI Too Large?
- What Do I Do If the CPU Usage of the Origin Server Reaches 100%?
- What Is the Connection Timeout Duration of WAF? Can I Manually Set the Timeout Duration?
- Checking Whether Normal Requests Are Blocked Mistakenly
- Checking for Permission Exceptions
- Videos
More Documents
User Guide (Paris)
- Introduction
- Monitoring Metrics
- Ports Supported by WAF
- Cloud WAF
Dedicated WAF Mode
- WAF Operation Guide
- Applying for a Dedicated WAF Instance
- Dashboard
- Events
Policies
- How to Configure WAF Protection
- Configuring Basic Protection Rules to Defend Against Common Web Attacks
- Configuring a CC Attack Protection Rule
- Creating a Reference Table to Configure Protection Metrics In Batches
- Managing Policies
- Website Settings
- System Management
- Authorizing and Associating an Enterprise Project
- Auditing
Best Practices
- Configuring the Minimum TLS Version and Cipher Suite to Better Secure Connections
- Configuring Anti-Crawler Rules to Prevent Crawler Attacks
- Configuring an Access Control Policy on an ECS or ELB to Protect Origin Servers
- Handling False Alarms to Get Improved Basic Web Protection
- Verifying a Global Protection Whitelist (Formerly False Alarm Masking) Rule by Simulating Requests with Postman
- WAF Cloud Mode Access Configuration
- Upgrading a Dedicated WAF Instance
- Obtaining Real Client IP Addresses
- Using LTS to Quickly Query and Analyze WAF Access Logs
- Using LTS to Analyze How WAF Blocks Spring Core RCE Vulnerability in Real Time
- Using LTS to Configure Block Alarms for WAF Rules
- Combining WAF and HSS to Get Improved Web Tamper Protection
- IAM Permissions Management
About the Product
- FAQs for Beginners
WAF Functions
- About WAF Protection
WAF Usage
- How Do I Obtain the Real IP Address of a Web Visitor?
- How Do I Configure My Server to Allow Only Requests from WAF?
- How Do I Configure WAF If a Reverse Proxy Server Is Deployed for My Website?
- Enterprise Project
- Service Request/Specification
- About Billing
Domain Name and Port Configuration
- How Do I Add a Domain Name/IP Address to WAF?
- Which Non-Standard Ports Does WAF Support?
- How Do I Use a Dedicated WAF Instance to Protect Non-Standard Ports That Are Not Supported by the Dedicated Instance?
- How Do I Configure Non-standard Ports When Adding a Protected Domain Name?
- What Can I Do If One of Ports on an Origin Server Does Not Require WAF Protection?
- What Data Is Required for Connecting a Domain Name/IP Address to WAF?
- How Do I Safely Delete a Protected Domain Name?
- Can I Change the Domain Name That Has Been Added to WAF?
- How Do I Route Website Traffic to My Cloud WAF Instance?
- Can I Configure Multiple Load Balancers for a Dedicated WAF Instance?
- Server Configuration
- Domain Name Resolution
- Operations After Connecting Websites to WAF
Service Interruption Check
- How Do I Troubleshoot 500/502/504 Errors?
- Why Is My Domain Name or IP Address Inaccessible?
- How Do I Handle False Alarms as WAF Blocks Normal Requests to My Website?
- How Can I Upload Files After the Website Is Connected to WAF?
- Why Does WAF Block Normal Requests as Invalid Requests?
- How Do I Whitelist IP Address Ranges of Cloud WAF?
- How Do I Solve the Problem of Excessive Redirection Times?
- Why Does the Website Login Page Continuously Refreshed After a Domain Name Is Connected to WAF?
- Why Does the Requested Page Respond Slowly After the HTTP Forwarding Policy Is Configured?
- Why Cannot I Access the Dedicated Engine Page?
Protection Rule Configuration
- Basic Web Protection
- CC Attack Protection Rules
- Precise Protection rules
- Anti-Crawler Protection
- Can I Export or Back Up the WAF Configuration?
- What Working Modes and Protection Mechanisms Does WAF Have?
- What Types of Protection Rules Does WAF Support?
- Which of the WAF Protection Rules Support the Log-Only Protective Action?
About the Product
- Change History
- Enabling WAF
- Dashboard
- Events
Policies
- Managing Policies
- Website Settings
- Object Management
- System Management
About WAF
WAF Functions
WAF Usage
- Will Traffic Be Permitted After WAF Is Switched to the Bypassed Mode?
Website Domain Name Access Configuration
- How Do I Configure a CC Attack Protection Rule?
- IP Address Blacklist and Whitelist
About WAF
- Change History
- Enabling WAF
- Dashboard
- Events
Policies
- Managing Policies
- Website Settings
- Object Management
- System Management
About WAF
WAF Functions
WAF Usage
About WAF
- Change History
User Guide (Ankara Region)
- Overview
- Applying for a Dedicated WAF Engine
- Enabling WAF Protection
Website Domain Name Management
- Switching WAF Working Mode
- Configuring Connection Timeout
- Configuring Connection Protection
- Updating a Certificate
- Removing a Protected Website from WAF
- Managing IP Address Blacklist and Whitelist Groups
Rule Configuration
- Configuration Guidance
- Configuring Basic Web Protection Rules
- Configuring a Precise Protection Rule
- Adding a Reference Table
- Configuring an IP Address Blacklist or Whitelist Rule
- Configuring a Geolocation Access Control Rule
- Configuring a Web Tamper Protection Rule
- Configuring an Information Leakage Prevention Rule
- Configuring a Global Protection Whitelist (Formerly False Alarm Masking) Rule
- Configuring a Data Masking Rule
- Dashboard
- Event Management
- Enabling Alarm Notifications
- Policy Management
- Dedicated WAF Engine Management
- Viewing Product Details
About WAF
WAF Functions
- Which OSs Does WAF Support?
- Which Layers Does WAF Provide Protection At?
- Does WAF Support File Caching?
- Does WAF Support Two-Way SSL Authentication?
- Does WAF Support Application Layer Protocol- and Content-Based Access Control?
- Can WAF Check the Body I Add to a POST Request?
- Can WAF Limit the Access Speed of a Domain Name?
- Can WAF Block Data Packets in multipart/form-data Format?
- Can a WAF Instance Be Deployed in the VPC?
- Can WAF Block URL Requests That Contain Special Characters?
- Can WAF Block Spam and Malicious User Registrations?
- Can WAF Block Requests for Calling Other APIs from Web Pages?
- Can WAF Limit Access Through Domain Names?
- Does WAF Have the IPS Module?
- Does WAF Cache Website Data?
- Is WAF a Hardware Firewall or a Software Firewall?
- Is There Any Impact on Origin Servers If I Enable HTTP/2 in WAF?
- How Does WAF Detect SQL Injection and XSS Attacks?
- Does a Dedicated WAF Instance Support Cross-VPC Protection?
WAF Usage
- Does WAF Affect Email Ports or Email Receiving and Sending?
- How Does WAF Block Requests?
- What Are Concurrent Requests?
- Can WAF Block Requests When a Certificate Is Mounted on ELB?
- Does WAF Affect My Existing Workloads and Server Running?
- Does WAF Affect Data Transmission from the Internal Network to an External Network?
- Do I Need to Make Some Changes in WAF If the Security Group for Origin Server (Address) Is Changed?
WAF Functions
- Can WAF Protect Multiple Domain Names That Point to the Same Origin Server?
- Is the Path of a WAF Protection Rule Case-sensitive?
- What Protection Rules Does WAF Support?
About WAF
- Change History
API Reference (Paris)
- Before You Start
- API Overview
- API Calling
APIs
Cloud Mode
- Resource Quotas
- Domain Names
- Protection Status and Domain Setup
- Policies
- Blacklist and Whitelist Rules
- Precise Protection Rules
- Data Masking Rules
- Web Tamper Protection Rules
- False Alarm Masking Rules
Event Logs
- Querying Attack Event Logs
- Querying Attack Event Logs by ID
- Querying Event Distribution
- Querying Request Statistics and Attack Statistics in a Specified Time Range
- Querying the Total Number of Attacks
- Querying Top N Attack Source IP Addresses
- Querying the Number of Attack Source IP Addresses
- Querying the Total Number of Requests per Second
- Querying the List of Event Log Files
- Alarm Notification
- Obtaining Option Details
- Interconnecting with Cloud Eye
Dedicated Mode
- Domain Names Protected by WAF
- Protection Status and Domain Name Access
- Policy Management
- Blacklist and Whitelist Rule Management
- CC Attack Protection Rule Management
- Precise Protection Rule Management
- Data Masking Rule Management
- Web Tamper Protection Rule Management
- False Alarm Masking Rule Management
- Dashboard
- Protection Event Management
Cloud Mode
- Appendix
- Change History
- Before You Start
- API Overview
- API Calling
API
- Policy Management
Rule Management
- Querying False Alarm Masking Rules
- Querying the List of Blacklist and Whitelist Rules
- Creating a Whitelist or Blacklist Rule
- Updating a Whitelist or Blacklist Rule
- Deleting a Whitelist or Blacklist Rule
- Adding a Data Masking Rule
- Querying the Geolocation Access Control Rule List
- Event Management
Protected Website Management in Dedicated Mode
- Connecting a Domain Name to a Dedicated WAF Instance
- Querying the List of Domain Names Connected to Dedicated WAF Instances
- Modifying the Configuration of a Domain Name Connected to a Dedicated WAF Instance
- Querying the Domain Name Configuration in Dedicated Mode
- Modifying the Protection Status of a Domain Name Connected to a Dedicated WAF Instance
- Dashboard
- Querying the Protected Domain Names
- Querying Features Available in a Site
Managing Websites Protected by Cloud WAF
- Querying Domain Names Protected by Cloud WAF
- Adding a Domain Name to Cloud WAF
- Modifying the Protection Status for a Domain Name
- Obtaining Domain Name Route Information in Cloud Mode
- Querying a Domain Name Protected by Cloud WAF by ID
- Updating a Domain Name Protected by Cloud WAF
- Removing a Domain Name from Cloud WAF
- Appendix
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- API Calling
APIs
- Querying Domain Names Protected by Dedicated WAF Engines
- Policy Management
Rule Management
- Event Management
- Appendix
- Change History
- Before You Start
- API Calling
APIs
- Policy Management
Rule Management
- Event Management
- Policy Management
Rule Management
- Event Management
- This API is used to query the list of domain names protected in cloud mode.
- Changing Protection Status of a Domain Name
- Policy Management
Rule Management
- Deleting a False Alarm Masking Rule
- Dashboard
- Event Management
- Appendix
- Change History
User Guide (Paris)
Step 4: Modify the DNS Records of the Domain Name
After a domain name is connected to WAF, WAF functions as a reverse proxy between the client and server. The real IP address of the server is hidden, and only the IP address of WAF is visible to web visitors. You must point the DNS resolution of the domain name to the CNAME record provided by WAF. In this way, access requests can be resolved to WAF.
To ensure that your WAF instance works properly, test it according to the instructions in Step 3: Test WAF before routing your business traffic to WAF.
- You have added the domain name you want to protect to the cloud WAF instance you have in CNAME access mode. For details, see Step 1: Add a Domain Name to WAF (Cloud Mode).
- You have the permission to modify domain name resolution settings on the DNS platform hosting your domain name.
- You have whitelisted WAF IP addresses on your origin servers.
- (Optional) You have tested your website connectivity to ensure that WAF can forward requests.
WAF protection takes effect only for real client IP addresses where requests originate. To ensure that WAF obtains real client IP addresses, if your website has layer-7 proxies such as CDN and cloud acceleration products deployed in front of WAF, Yes must be selected for Proxy Configured.
Specification Limitations
After your website is connected to WAF, you can upload a file no larger than 10 GB each time.
How WAF Works
- No proxy used
DNS resolves your domain name to the origin server IP address before the site is connected to WAF. DNS resolves your domain name to the CNAME of WAF after the site is connected to WAF. Then WAF inspects the incoming traffic and filters out malicious traffic.
- A proxy (such as anti-DDoS service) used
If a proxy such as anti-DDoS service is used on your site before it is connected to WAF, DNS resolves the domain name of your site to the anti-DDoS IP address. The traffic goes to the anti-DDoS service and the anti-DDoS service then routes the traffic back to the origin server. After you connect your website to WAF, change the back-to-source address of the proxy (such as anti-DDoS service) to the CNAME of WAF. In this way, the proxy forwards the traffic to WAF. WAF then filters out illegitimate traffic and only routes legitimate traffic back to the origin server.
- To ensure that WAF can properly forward requests, test WAF by referring to Testing WAF before modifying the DNS configuration.
- To prevent other users from configuring your domain names on WAF in advance (this will cause interference on your domain name protection), add the subdomain name and TXT record on your DNS management platform. WAF can determine which user owns the domain name based on the subdomain name and TXT record.
Operation Guide
After a domain name is added, WAF generates a CNAME record, or CNAME, subdomain name, and TXT record for DNS to resolve the domain name to WAF so that website traffic can pass through WAF for detection. For details, see Table 1.
Scenario |
Generated Parameter Value |
Operation Related to Domain Name Resolution |
No proxy used |
CNAME |
The DNS obtains the CNAME of WAF. |
Proxy used |
CNAME, subdomain name, and TXT record |
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the upper left corner and choose Web Application Firewall under Security.
- In the navigation pane on the left, choose Website Settings.
- In the row containing the desired domain name, click the domain name to go to the Basic Information page.
- In the CNAME row, click
to copy the CNAME record.
If the message "CNAME copied successfully" is displayed in the upper right corner of the page, the CNAME record is copied successfully.
- Connect the domain name to WAF.
- No proxy used
Configure the CNAME record at your DNS provider. For details, contact your DNS provider.
- Proxy used
Change the back-to-source IP address of the used proxy, such as anti-DDoS and CDN services, to the copied CNAME record.
- Obtain Subdomain Name and TXT Record: In the row of Access Status, click How to Access. In the Access Guide dialog box, copy Subdomain Name and TXT Record.
- Add Subdomain Name at the DNS provider and configure TXT Record for the subdomain name.
WAF determines which user owns the domain name based on the configured Subdomain Name and TXT Record.
- No proxy used
- Verify that the CNAME of the domain name has been configured.
- In Windows, choose Start > Run. Then enter cmd and press Enter.
- Run a nslookup command to query the CNAME record.
If the configured CNAME is returned, the configuration is successful.
Example command:
nslookup www.example.com
Follow-up Procedure
- If your server uses other network firewalls, disable these network firewalls or add the WAF IP address range to the IP address whitelist of these network firewalls. Otherwise, these firewalls may regard the WAF IP address as a malicious IP address.
- If your web server is using personal security software, replace it with enterprise security software and whitelist the WAF IP address ranges.
Verification
- By default, WAF detects the Access Status of each protected domain name on an hourly basis.
- Generally, if you have performed domain connection and Access Status is Accessible, the domain name is connected to WAF.
