Help Center/ Web Application Firewall/ User Guide (ME-Abu Dhabi Region) / Policies/ Configuring Custom Precise Protection Rules
Updated on 2024-03-14 GMT+08:00
You can combine common HTTP fields, such as IP, Path, Referer, User Agent, and Params in a protection rule to let WAF allow, block, or only log the requests that match the combined conditions.
A reference table can be added to a precise protection rule. The reference table takes effect for all protected domain names.
You have added your website to a policy.
  • It takes several minutes for a new rule to take effect. After the rule takes effect, protection events triggered by the rule will be displayed on the Events page.
  • If you configure Protective Action to Block for a precise protection rule, you can configure a known attack source rule by referring to Configuring a Known Attack Source Rule to Block Specific Visitors for a Specified Duration. WAF will block requests matching the configured IP address, Cookie, or Params for a length of time configured as part of the rule.
  • The path content cannot contain the following special characters: (' "<>&*#%\?)
Application Scenarios
Precise protection rules are used for anti-leeching and website management background protection.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner and choose Web Application Firewall under Security & Compliance.
  4. In the navigation pane on the left, choose Policies.
  5. Click the name of the target policy to go to the protection configuration page.
  6. In the Precise Protection configuration area, change Status as needed and click Customize Rule to go to the Precise Protection page.
    Figure 1 Precise Protection configuration area
  7. On the Precise Protection page, set Detection Mode.
    Two detection modes are available:
    • Instant Detection: If a request matches a configured precise protection rule, WAF immediately ends threat detection and blocks the request.
    • Full Detection: If a request matches a configured precise protection rule, WAF finishes its scan first and then blocks all requests that match the configured precise protection rule.
  8. In the upper left corner above the Precise Protection rule list, click Add Rule.
  9. In the displayed dialog box, add a rule by referring to Table 1.
    The settings shown in Figure 2 are used as an example. If a visitor tries to access a URL containing /admin, WAF will block the request.
    NOTICE:
    To ensure that WAF blocks only attack requests, configure Protective Action to Log only first and check whether normal requests are blocked on the Events page. If no normal requests are blocked, configure Protective Action to Block.
    Figure 2 Add Precise Protection Rule
    Table 1 Rule parameters
    Example Value
    Rule Description
    A brief description of the rule. This parameter is optional.
    None
    Condition List
    Click Add to add conditions. At least one condition needs to be added. You can add up to 30 conditions to a protection rule. If more than one condition is added, all of the conditions must be met for the rule to be applied. A condition includes the following parameters:
    Parameters for configuring a condition are described as follows:
    • Field
    • Subfield: Configure this field only when Params, Cookie, or Header is selected for Field.
    • Logic: Select a logical relationship from the drop-down list.
      • If Include any value, Exclude any value, Equal to any value, Not equal to any value, Prefix is any value, Prefix is not any of them, Suffix is any value, or Suffix is not any of them is selected, select an existing reference table in the Content drop-down list. For details, see Creating a Reference Table to Configure Protection Metrics In Batches.
      • Exclude any value, Not equal to any value, Prefix is not any of them, and Suffix is not any of them indicates, respectively, that WAF performs the protection action (block, allow, or log only) when the field in the access request does not contain, is not equal to, or the prefix or suffix is not any value set in the reference table. For example, assume that Path field is set to Exclude any value and the test reference table is selected. If test1, test2, and test3 are set in the test reference table, WAF performs the protection action when the path of the access request does not contain test1, test2, or test3.
    • Content: Enter or select the content of condition matching.
    For more details about the configurations in general, see Table 1.
    • Path Include /admin
    • User Agent Prefix is not mozilla/5.0
    • IP Equal to 192.168.2.3
    • Cookie key1 Prefix is not jsessionid
    Protective Action
    • Block: The request that hit the rule will be blocked and a block response page is returned to the client that initiates the request. By default, WAF uses a unified block response page. You can also customize this page. For details, see Modifying the Alarm Page.
    • Allow: Requests that hit the rule are forwarded to backend servers.
    • Log only: Requests that hit the rule are not blocked, but will be logged. You can use WAF logs to query requests that hit the current rule and analyze the protection results of the rule. For example, check whether there are requests that are blocked mistakenly.
    Block
    Known Attack Source
    If you set Protective Action to Block, you can select a blocking type for a known attack source rule. Then, WAF blocks requests matching the configured IP, Cookie, or Params for a length of time that depends on the selected blocking type.
    Long-term IP address blocking
    Priority
    Rule priority. If you have added multiple rules, rules are matched by priority. The smaller the value you set, the higher the priority.
    NOTICE:
    If multiple precise access control rules have the same priority, WAF matches the rules in the sequence of time the rules are added.
    5
    Effective Date
    Select Immediate to enable the rule immediately, or select Custom to configure when you wish the rule to be enabled.
    Immediate
  10. Click Confirm. You can then view the added precise protection rule in the protection rule list.
    • To disable a rule, click Disable in the Operation column of the rule. The default Rule Status is Enabled.
    • To modify a rule, click Modify in the row containing the rule.
    • To delete a rule, click Delete in the row containing the rule.
Protection Effect
If you have configured a precise protection rule as shown in Figure 2 for your domain name, to verify WAF is protecting your website (www.example.com) against the rule:
  1. Clear the browser cache and enter the domain name in the address bar to check whether the website is accessible.
    • If the website is inaccessible, connect the website domain name to WAF by following the instructions in Website Settings.
    • If the website is accessible, go to Step 2.
  2. Clear the browser cache and enter http://www.example.com/admin (or any page containing /admin) in the address bar. Normally, WAF blocks the requests that meet the conditions and returns the block page.
  3. Return to the WAF console. In the navigation pane, click Events. On the displayed page, view or download events data.
Configuration Example - Blocking a Certain Type of Attack Requests
Analysis of a specific type of WordPress pingback attack shows that the User Agent field contains WordPress.
Figure 3 WordPress pingback attack
A precise rule as shown in the figure can block this type of attack.
Figure 4 User Agent configuration
Configuration Example - Blocking Attack Requests to a Certain URL
If a large number of IP addresses are accessing a URL that does not exist, configure the following protection rule to block such requests to reduce resource usage on the origin server.
Figure 5 Blocking requests to a specific URL
Configuration Example - Blocking Requests with null Fields
You can configure precise protection rules to block requests having null fields.
Figure 6 Blocking requests with empty Referer
Configuration Example - Blocking Specified File Types (ZIP, TAR, and DOCX)
You can configure file types that match the path field to block specific files of certain types. For example, if you want to block .zip files, you can configure a precise protection rule as shown in Figure 7 to block access requests of .zip files.
Figure 7 Blocking requests of specific file types
Configuration Example - Preventing Hotlinking
You can configure a protection rule based on the Referer field to enable WAF to block hotlinking from a specific website. If you find out that, for example, requests from https://abc.blog.com are stealing images from your site, you can configure a rule to block such requests.
Figure 8 Preventing hotlinking
Configuration Example - Allowing a Specified IP Address to Access Your Website
You can configure two precise protection rules, one to block all requests, as shown in Figure 9, but then another one to allow the access from a specific IP address, as shown in Figure 10.
Figure 9 Blocking all requests
Figure 10 Allowing the access of a specified IP address
Configuration Example - Allowing a Specific IP Address to Access a Certain URL
You can configure multiple conditions in the Condition List field. If an access request meets the conditions in the list, WAF will allow the request from a specific IP address to access a specified URL.
Figure 11 Allowing specific IP addresses to access specified URLs
