Help Center/ Web Application Firewall/ User Guide (ME-Abu Dhabi Region) / Policies/ Configuring Basic Protection Rules to Defend Against Common Web Attacks
Updated on 2024-03-14 GMT+08:00
After this function is enabled, WAF can defend against common web attacks, such as SQL injections, XSS, remote overflow vulnerabilities, file inclusions, Bash vulnerabilities, remote command execution, directory traversal, sensitive file access, and command/code injections. You can also enable other checks in basic web protection, such as web shell detection, deep inspection against evasion attacks, and header inspection.
You have added your website to a policy.
  • Basic web protection has two modes: Block and Log only.
  • It takes several minutes for a new rule to take effect. After the rule takes effect, protection events triggered by the rule will be displayed on the Events page.
  • If you select Block for Basic Web Protection, you can configure access control criteria for a known attack source. WAF will block requests matching the configured IP address, cookie, or params for a length of time configured as part of the rule.
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner and choose Web Application Firewall under Security & Compliance.
  4. In the navigation pane on the left, choose Policies.
  5. Click the name of the target policy to go to the protection configuration page.
  6. In the Basic Web Protection configuration area, change Status and Mode as needed by referring to Table 1.
    Figure 1 Basic Web Protection configuration area
    Table 1 Parameter description
    Status
    Status of Basic Web Protection
    • : enabled.
    • : disabled.
    Mode
    • Block: WAF blocks and logs detected attacks.
    • Log only: WAF only logs detected attacks.
  7. In the Basic Web Protection configuration area, click Advanced Settings.
  8. Click the Protection Status tab, and enable protection types one by one by referring to Table 3.
    Figure 2 Basic web protection
    1. Set the protective action.
    2. Set the protection level.
      In the upper part of the page, set Protection Level to Low, Medium, or High. The default value is Medium.
      Table 2 Protection levels
      Protection Level
      Low
      WAF only blocks the requests with obvious attack signatures.
      If a large number of false alarms are reported, Low is recommended.
      Medium
      The default level is Medium, which meets a majority of web protection requirements.
      High
      At this level, WAF provides the finest granular protection and can intercept attacks with complex bypass features, such as Jolokia cyber attacks, common gateway interface (CGI) vulnerability detection, and Druid SQL injection attacks.
      To let WAF defend against more attacks but make minimum effect on normal requests, observe your workloads for a period of time first. Then, configure a global protection whitelist rule and select High.
    3. Set the protection type.
      NOTICE:
      By default, General Check is enabled. You can enable other protection types by referring to Table 3.
    Table 3 Protection types
    Type
    General Check
    Defends against attacks such as SQL injections, XSS, remote overflow vulnerabilities, file inclusions, Bash vulnerabilities, remote command execution, directory traversal, sensitive file access, and command/code injections. SQL injection attacks are mainly detected based on semantics.
    If you enable General Check, WAF checks your websites based on the built-in rules.
    Webshell Detection
    Protects against web shells from upload interface.
    If you enable Webshell Detection, WAF detects web page Trojan horses inserted through the upload interface.
    Deep Inspection
    Identifies and blocks evasion attacks, such as the ones that use homomorphic character obfuscation, command injection with deformed wildcard characters, UTF7, data URI scheme, and other techniques.
    If you enable Deep Inspection, WAF detects and defends against evasion attacks in depth.
    Header Inspection
    This function is disabled by default. When it is disabled, General Check will check some of the header fields, such as User-Agent, Content-type, Accept-Language, and Cookie.
    If you enable this function, WAF checks all header fields in the requests.
Protection Effect
If General Check is enabled and Mode is set to Block for your domain name, to verify WAF is protecting your website (www.example.com) against general check items:
  1. Clear the browser cache and enter the domain name in the address bar to check whether the website is accessible.
    • If the website is inaccessible, connect the website domain name to WAF by following the instructions in Website Settings.
    • If the website is accessible, go to Step 2.
  2. Clear the browser cache and enter http://www.example.com?id=1%27%20or%201=1 in the address box of the browser to simulate an SQL injection attack.
  3. Return to the WAF console. In the navigation pane, choose Events. On the displayed page, view or download events data.
Example - Blocking SQL Injection Attacks
If domain name www.example.com has been connected to WAF, perform the following steps to verify that WAF can block SQL injection attacks.
  1. Enable General Check in Basic Web Protection and set the protection mode to Block.
  2. Enable WAF basic web protection.
    Figure 3 Basic Web Protection configuration area
  3. Clear the browser cache and enter a simulated SQL injection (for example, http://www.example.com?id=' or 1=1) in the address box.
    WAF blocks the access request. Figure 4 shows an example block page.
    Figure 4 Block page
  4. Go to the WAF console. In the navigation pane on the left, choose Events. View the event on the Events page.
