Updated on 2025-05-15 GMT+08:00
Editing Server Information
If you select Cloud or Dedicated when adding a website to WAF, you can edit the server information of your website.
Applicable scenarios:
  • Edit server information.
    • Cloud mode: You can modify configurations for Client Protocol, Server Protocol, Server Address, and Server Port.
    • Dedicated mode: You can modify configurations for Client Protocol, Server Protocol, Server Address, VPC, and Server Port.
  • Add server configurations.
  • Update a certificate by referring to Updating the Certificate Used for a Website.
If PCI DSS/3DS compliance check is enabled, the client protocol cannot be changed, and no origin server addresses can be added.
Impact on the System
Modifying the server configuration does not affect services.
Modifying Server Information of One Website
  2. Click in the upper left corner of the management console and select a region or project.
  3. Click in the upper left corner of the page and choose Security > Web Application Firewall.
  4. In the navigation pane on the left, choose Website Settings.
  5. In the Domain Name column, click the domain name of the website to go to the basic information page.
  6. In the Server Information area, click .
  7. In the Edit Server Information dialog box, edit the server configurations and associated certificates as needed.
  8. Click Confirm.
