- What's New
- Function Overview
- Billing
- Getting Started
User Guide
VPC Endpoint Services
- VPC Endpoint Service Overview
- Creating a VPC Endpoint Service
- Viewing a VPC Endpoint Service
- Deleting a VPC Endpoint Service
- Managing Connections of a VPC Endpoint Service
- Managing Whitelist Records of a VPC Endpoint Service
- Managing Port Mappings of a VPC Endpoint Service
- Managing Tags of a VPC Endpoint Service
- VPC Endpoints
- Accessing OBS
- Using Cloud Eye to Monitor VPC Endpoints
- Using CTS to Audit VPC Endpoints
- Permissions Management
- Quotas
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Version Management
- Querying VPC Endpoint Services
- Querying Details of a VPC Endpoint Service
- Modifying a VPC Endpoint Service
- Querying Connections to a VPC Endpoint Service
- Accepting or Rejecting a VPC Endpoint
- Querying Whitelist Records of a VPC Endpoint Service
- Batch Adding or Deleting Whitelist Records of a VPC Endpoint Service
- Querying Public VPC Endpoint Services
- Querying Basic Information About a VPC Endpoint Service
- Changing the Name of a VPC Endpoint Service
- Updating Descriptions of VPC Endpoint Connections
- Batch Adding Whitelist Records of a VPC Endpoint Service
- Batch Deleting Whitelist Records of a VPC Endpoint Service
- Updating the Description of a Whitelist Record of a VPC Endpoint Service
- VPC Endpoints
- Resource Quotas
- Tags
- Application Examples
- Appendix
- SDK Reference
- FAQs
More Documents
- Getting Started
- Viewing Summary of a VPC Endpoint Service
- Viewing Port Mappings of a VPC Endpoint Service
- VPC Endpoints
- Permission Management
- FAQs
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
APIs for Managing VPC Endpoint Services
- Querying Connections of a VPC Endpoint Service
- Querying the Whitelist Records of a VPC Endpoint Service
- APIs for Managing VPC Endpoints
- Resource Quota
- Tag Function
- Appendix
- Change History
User Guide (Paris Region)
Getting Started
- Operation Guide
- Configuring a VPC Endpoint for Communications Across VPCs of the Same Domain
- Configuring a VPC Endpoint for Communications Across VPCs of Different Domains
- Configuring a VPC Endpoint for Accessing the Private IP Address of OBS over Private Networks
- Configuring a VPC Endpoint for Accessing the Public IP Address of OBS over Public Networks
- Viewing the Summary of a VPC Endpoint Service
- VPC Endpoints
- Quotas
- FAQ
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Querying Details About a VPC Endpoint Service
- Resource Quota
- Tag Function
- Appendix
- Change History
- Getting Started
- VPC Endpoints
- Quotas
- FAQ
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Tag Function
- Appendix
- Change History
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Appendix
- Change History
Querying and Accessing a VPC Endpoint
After a VPC endpoint is created, you can query its details and access it.
Querying a VPC Endpoint
Perform the following operations to query details about a VPC endpoint, including the ID, associated VPC endpoint service name, VPC, and status.
- Click
in the upper left corner and select the required region and project.
- Choose Service List > Networking > VPC Endpoint.
On the displayed page, locate the target VPC endpoint by entering a keyword in the search box in the upper right corner:
- Search by VPC endpoint service name or VPC endpoint ID.
- Select VPC endpoint service name or ID in the filter box.
- Enter a keyword in the search box.
- Click
to start the search.
VPC endpoints containing the keyword are displayed in the VPC endpoint list.
- Search by preset tag.
- Click
in Search by Tag.
- Enter a tag and a value.
Enter a key or value or select a key or value from the drop-down list.
You can use a maximum of 10 tags to search for a VPC endpoint.
- Click Search.
VPC endpoints containing the specified tag are displayed in the VPC endpoint list.
If you set multiple tags, VPC endpoints containing all the specified tags will be displayed.
- Click
- In the VPC endpoint list, click
before the target VPC endpoint to view its details.
After a VPC endpoint is created, a private IP address is assigned.
Table 1 Required parameters Parameter
VPC Endpoint Service Name
Specifies the name of the VPC endpoint service that the VPC endpoint is used to access.
Private IP Address
Specifies the IP address for accessing the VPC endpoint.
Private Domain Name
Specifies the private domain name for accessing the VPC endpoint.
Accessing a VPC Endpoint Using a Private IP Address
Perform the following operations to access a VPC endpoint using its private IP address:
- In the VPC that the VPC endpoint belongs to, log in to the backend resource, for example, an ECS.
- Select a command based on the backend resource type and run the command to access the VPC endpoint. The command format is as follows:
Command Private IP address:Port number
The following is a command example:
curl Private IP address:Port number
Accessing a VPC Endpoint (Using a Private Domain Name)
You can access a VPC endpoint using its private domain name if you select Create a Private Domain Name when creating the endpoint.
The system automatically creates a private zone for the generated domain name and adds A record set for the private zone to resolve the domain name into the private IP address of the VPC endpoint.
You can view the corresponding private zone and its resolution records on the DNS console.
Viewing the record set of the private domain name
- In the service list, choose Network > Domain Name Service.
The DNS console is displayed.
- In the navigation pane, choose Private Zones.
The Private Zones page is displayed.
- In the private zone list, click the name of the target private zone.
- In the record set list, locate the target A record set and view its information.
When the value in the Status column changes to Normal, the resolution takes effect.
Accessing a VPC endpoint using a private domain name
Command Private domain name:Port number
curl Private domain name:Port number
