- What's New
- Function Overview
- Billing
- Getting Started
User Guide
VPC Endpoint Services
- VPC Endpoint Service Overview
- Creating a VPC Endpoint Service
- Viewing a VPC Endpoint Service
- Deleting a VPC Endpoint Service
- Managing Connections of a VPC Endpoint Service
- Managing Whitelist Records of a VPC Endpoint Service
- Managing Port Mappings of a VPC Endpoint Service
- Managing Tags of a VPC Endpoint Service
- VPC Endpoints
- Accessing OBS
- Using Cloud Eye to Monitor VPC Endpoints
- Using CTS to Audit VPC Endpoints
- Permissions Management
- Quotas
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Version Management
- Querying VPC Endpoint Services
- Querying Details of a VPC Endpoint Service
- Modifying a VPC Endpoint Service
- Querying Connections to a VPC Endpoint Service
- Accepting or Rejecting a VPC Endpoint
- Querying Whitelist Records of a VPC Endpoint Service
- Batch Adding or Deleting Whitelist Records of a VPC Endpoint Service
- Querying Public VPC Endpoint Services
- Querying Basic Information About a VPC Endpoint Service
- Changing the Name of a VPC Endpoint Service
- Updating Descriptions of VPC Endpoint Connections
- Batch Adding Whitelist Records of a VPC Endpoint Service
- Batch Deleting Whitelist Records of a VPC Endpoint Service
- Updating the Description of a Whitelist Record of a VPC Endpoint Service
- VPC Endpoints
- Resource Quotas
- Tags
- Application Examples
- Appendix
- SDK Reference
- FAQs
More Documents
- Getting Started
- Viewing Summary of a VPC Endpoint Service
- Viewing Port Mappings of a VPC Endpoint Service
- VPC Endpoints
- Permission Management
- FAQs
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
APIs for Managing VPC Endpoint Services
- Querying Connections of a VPC Endpoint Service
- Querying the Whitelist Records of a VPC Endpoint Service
- APIs for Managing VPC Endpoints
- Resource Quota
- Tag Function
- Appendix
- Change History
User Guide (Paris Region)
Getting Started
- Operation Guide
- Configuring a VPC Endpoint for Communications Across VPCs of the Same Domain
- Configuring a VPC Endpoint for Communications Across VPCs of Different Domains
- Configuring a VPC Endpoint for Accessing the Private IP Address of OBS over Private Networks
- Configuring a VPC Endpoint for Accessing the Public IP Address of OBS over Public Networks
- Viewing the Summary of a VPC Endpoint Service
- VPC Endpoints
- Quotas
- FAQ
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Querying Details About a VPC Endpoint Service
- Resource Quota
- Tag Function
- Appendix
- Change History
- Getting Started
- VPC Endpoints
- Quotas
- FAQ
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Tag Function
- Appendix
- Change History
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Appendix
- Change History
This section describes how to query summary of a VPC endpoint service, including the name, ID, backend resource type, backend resource name, VPC, status, connection approval, service type, and creation time.
- Click
in the upper left corner and select the required region and project.
- Choose Service List > Networking > VPC Endpoint.
- In the navigation pane on the left, choose VPC Endpoint > VPC Endpoint Services.
Locate the target VPC endpoint service by entering a filter in the search box in the upper right corner:
- Search by name or ID.
- Select Name or ID in the filter box.
- Enter a keyword in the search box.
- Click
to start the search.
VPC endpoint services containing the keyword are displayed in the list.
- Search by preset tag.
- Click
in Search by Tag.
- Enter a tag and a value.
Enter a key or value or select a key or value from the drop-down list.
You can use a maximum of 10 tags to search for a VPC endpoint service.
- Click Search.
The VPC endpoint service containing the specified tag is displayed in the list.
If you set multiple tags, VPC endpoint services containing all the specified tags will be displayed.
- Click
- In the VPC endpoint service list, locate the target VPC endpoint service and click its name to view the details.
Table 1 describes the parameters displayed on the VPC endpoint service details page.
Table 1 Parameter description Tab
Summary
Name
Specifies the name of the VPC endpoint service.
ID
Specifies the ID of the VPC endpoint service.
Backend Resource Type
Specifies the type of the backend resource that provides services.
Backend Resource Name
Specifies the name of the backend resource that provides services to be accessed.
VPC
Specifies the region where the VPC endpoint service is deployed.
Status
Specifies the status of the VPC endpoint service.
Connection Approval
Specifies whether connection approval is required.
Service Type
Specifies the type of the VPC endpoint service.
Created
Specifies the creation time of the VPC endpoint service.
Connection Management
VPC Endpoint ID
Specifies the ID of the VPC endpoint.
Packet ID
Specifies the identifier of the VPC endpoint ID.
Status
Specifies the status of the VPC endpoint.
For details about statuses of a VPC endpoint, see What Are Statuses of VPC Endpoint Services and VPC Endpoints?
Owner
Specifies the domain ID of the VPC endpoint owner.
Created
Specifies the creation time of the VPC endpoint.
Operation
Specifies whether to allow a VPC endpoint to connect to a VPC endpoint service. The value can be Accept or Reject.
Authorized Domain ID
Specifies the authorized domain ID for connecting to the VPC endpoint. The value can also be *.
If you add an asterisk (*) to the whitelist, it means that all users can access the VPC endpoint service.
Operation
Specifies whether to delete an authorized domain from the whitelist.
Port Mapping
Protocol
Specifies the protocol used for communication between the VPC endpoint service and VPC endpoint.
Service Port
Specifies the port provided by the backend service bound to the VPC endpoint service.
Terminal Port
Specifies the port provided by the VPC endpoint, allowing you to access the VPC endpoint service.
Tag
Key
Specifies the tag key of the VPC endpoint service.
Value
Specifies the tag value of the VPC endpoint service.
Operation
Specifies the operation on the VPC endpoint service tag, for example, you can select Edit or Delete.
