- What's New
- Function Overview
- Billing
- Getting Started
User Guide
VPC Endpoint Services
- VPC Endpoint Service Overview
- Creating a VPC Endpoint Service
- Viewing a VPC Endpoint Service
- Deleting a VPC Endpoint Service
- Managing Connections of a VPC Endpoint Service
- Managing Whitelist Records of a VPC Endpoint Service
- Managing Port Mappings of a VPC Endpoint Service
- Managing Tags of a VPC Endpoint Service
- VPC Endpoints
- Accessing OBS
- Using Cloud Eye to Monitor VPC Endpoints
- Using CTS to Audit VPC Endpoints
- Permissions Management
- Quotas
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Version Management
- Querying VPC Endpoint Services
- Querying Details of a VPC Endpoint Service
- Modifying a VPC Endpoint Service
- Querying Connections to a VPC Endpoint Service
- Accepting or Rejecting a VPC Endpoint
- Querying Whitelist Records of a VPC Endpoint Service
- Batch Adding or Deleting Whitelist Records of a VPC Endpoint Service
- Querying Public VPC Endpoint Services
- Querying Basic Information About a VPC Endpoint Service
- Changing the Name of a VPC Endpoint Service
- Updating Descriptions of VPC Endpoint Connections
- Batch Adding Whitelist Records of a VPC Endpoint Service
- Batch Deleting Whitelist Records of a VPC Endpoint Service
- Updating the Description of a Whitelist Record of a VPC Endpoint Service
- VPC Endpoints
- Resource Quotas
- Tags
- Application Examples
- Appendix
- SDK Reference
- FAQs
More Documents
- Getting Started
- Viewing Summary of a VPC Endpoint Service
- Viewing Port Mappings of a VPC Endpoint Service
- VPC Endpoints
- Permission Management
- FAQs
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
APIs for Managing VPC Endpoint Services
- Querying Connections of a VPC Endpoint Service
- Querying the Whitelist Records of a VPC Endpoint Service
- APIs for Managing VPC Endpoints
- Resource Quota
- Tag Function
- Appendix
- Change History
User Guide (Paris Region)
Getting Started
- Operation Guide
- Configuring a VPC Endpoint for Communications Across VPCs of the Same Domain
- Configuring a VPC Endpoint for Communications Across VPCs of Different Domains
- Configuring a VPC Endpoint for Accessing the Private IP Address of OBS over Private Networks
- Configuring a VPC Endpoint for Accessing the Public IP Address of OBS over Public Networks
- Viewing the Summary of a VPC Endpoint Service
- VPC Endpoints
- Quotas
- FAQ
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Querying Details About a VPC Endpoint Service
- Resource Quota
- Tag Function
- Appendix
- Change History
- Getting Started
- VPC Endpoints
- Quotas
- FAQ
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Tag Function
- Appendix
- Change History
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Appendix
- Change History
Show all
Step 1: Create a VPC Endpoint Service
To enable communication across two VPCs, you first need to configure a cloud resource (backend resource) in one VPC as a VPC endpoint service.
This section describes how to create a VPC endpoint service by selecting an elastic load balancer as an example backend service in VPC 2 using domain B.
There are available backend resources in the same VPC.
- Click
in the upper left corner and select the required region and project.
- Choose Service List > Networking > VPC Endpoint.
- In the navigation pane on the left, choose VPC Endpoint > VPC Endpoint Services and click Create VPC Endpoint Service.
The Create VPC Endpoint Service page is displayed.
- Set the required parameters.
Table 1 Required parameters Parameter
Region
Specifies the region where the VPC endpoint service is located.
Resources in different regions cannot communicate with each other over internal networks. Select the nearest region for lower network latency and faster access to resources.
VPC
Specifies the VPC where the VPC endpoint service is located.
Service Type
Specifies the type of the VPC endpoint service. The value can only be Interface.
Connection Approval
Specifies whether the connection between a VPC endpoint and a VPC endpoint service requires approval from the owner of the VPC endpoint service.
You can determine whether to enable or disable the connection approval.
If connection approval is enabled, any VPC endpoint for connecting to the VPC endpoint service needs to be approved. For details, see step 7.
Port Mapping
Specifies the protocol and ports used for communication between the VPC endpoint service and VPC endpoint. The protocol is TCP.
- Service Port: A service port is provided by the backend service bound to the endpoint service.
- Terminal Port: A terminal port is provided by the VPC endpoint, allowing you to access the VPC endpoint service.
The service and terminal port numbers range from 1 to 65535. A maximum of 50 port mappings can be added at a time.
Accessing a VPC endpoint service from a VPC endpoint is to access the service port from the associated terminal port.
Backend Resource Type
Specifies the type of the backend resource that provides services to be accessed.
The following backend resources are supported:
- Elastic load balancer: Backend resources of this type suit services that receive high access traffic and demand high reliability and disaster recovery (DR) performance.
- ECS: Backend resources of this type serve as servers.
Example: Elastic load balancerNOTE:
Security groups use the whitelist mechanism. For the security group containing the backend resource configured for the VPC endpoint service, add an inbound rule, with the source IP address set to 198.19.128.0/20. For details, see section "Adding a Security Group Rule" in the Virtual Private Cloud User Guide.
Load Balancer
When Backend Resource Type is set to Elastic load balancer, select the load balancer that provides services from the drop-down list.
If an elastic load balancer is used as the backend resource, the source IP address received by the VPC endpoint service is not the real address of the client.
Tag
This parameter is optional.
Specifies the VPC endpoint service tag, which consists of a key and a value. You can add a maximum of 10 tags to each VPC endpoint service.
Tag keys and values must meet requirements listed in Table 2.
Table 2 Tag requirements for VPC endpoint services Parameter
Requirement
Tag key
- Cannot be left blank.
- Must be unique for each resource.
- Can contain a maximum of 36 Unicode characters.
- Cannot start or end with a space or contain special characters =*<>\,|/
Tag value
- Can contain a maximum of 43 Unicode characters.
- Click Create Now.
- Click Back to VPC Endpoint Service List to view the newly-created VPC endpoint service.
- In the VPC endpoint service list, locate the target VPC endpoint service and click its name to view the details.
