- What's New
- Function Overview
- Billing
- Getting Started
User Guide
VPC Endpoint Services
- VPC Endpoint Service Overview
- Creating a VPC Endpoint Service
- Viewing a VPC Endpoint Service
- Deleting a VPC Endpoint Service
- Managing Connections of a VPC Endpoint Service
- Managing Whitelist Records of a VPC Endpoint Service
- Managing Port Mappings of a VPC Endpoint Service
- Managing Tags of a VPC Endpoint Service
- VPC Endpoints
- Accessing OBS
- Using Cloud Eye to Monitor VPC Endpoints
- Using CTS to Audit VPC Endpoints
- Permissions Management
- Quotas
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Version Management
- Querying VPC Endpoint Services
- Querying Details of a VPC Endpoint Service
- Modifying a VPC Endpoint Service
- Querying Connections to a VPC Endpoint Service
- Accepting or Rejecting a VPC Endpoint
- Querying Whitelist Records of a VPC Endpoint Service
- Batch Adding or Deleting Whitelist Records of a VPC Endpoint Service
- Querying Public VPC Endpoint Services
- Querying Basic Information About a VPC Endpoint Service
- Changing the Name of a VPC Endpoint Service
- Updating Descriptions of VPC Endpoint Connections
- Batch Adding Whitelist Records of a VPC Endpoint Service
- Batch Deleting Whitelist Records of a VPC Endpoint Service
- Updating the Description of a Whitelist Record of a VPC Endpoint Service
- VPC Endpoints
- Resource Quotas
- Tags
- Application Examples
- Appendix
- SDK Reference
- FAQs
More Documents
- Getting Started
- Viewing Summary of a VPC Endpoint Service
- Viewing Port Mappings of a VPC Endpoint Service
- VPC Endpoints
- Permission Management
- FAQs
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
APIs for Managing VPC Endpoint Services
- Querying Connections of a VPC Endpoint Service
- Querying the Whitelist Records of a VPC Endpoint Service
- APIs for Managing VPC Endpoints
- Resource Quota
- Tag Function
- Appendix
- Change History
User Guide (Paris Region)
Getting Started
- Operation Guide
- Configuring a VPC Endpoint for Communications Across VPCs of the Same Domain
- Configuring a VPC Endpoint for Communications Across VPCs of Different Domains
- Configuring a VPC Endpoint for Accessing the Private IP Address of OBS over Private Networks
- Configuring a VPC Endpoint for Accessing the Public IP Address of OBS over Public Networks
- Viewing the Summary of a VPC Endpoint Service
- VPC Endpoints
- Quotas
- FAQ
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Querying Details About a VPC Endpoint Service
- Resource Quota
- Tag Function
- Appendix
- Change History
- Getting Started
- VPC Endpoints
- Quotas
- FAQ
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Tag Function
- Appendix
- Change History
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Appendix
- Change History
Step 2: Create a VPC Endpoint
After you create a VPC endpoint service, you also need to create a VPC endpoint to access the VPC endpoint service.
This section describes how to create a VPC endpoint in another VPC of your own for connecting to the VPC endpoint service.
Select the same region and project as those of the VPC endpoint service.
- Click
in the upper left corner and select the required region and project.
- Choose Service List > Networking > VPC Endpoint.
- On the VPC Endpoints page, click Create VPC Endpoint.
The Create VPC Endpoint page is displayed.
- Set the required parameters.
Table 1 Required parameters Parameter
Region
Specifies the region where the VPC endpoint is located. This region is the same as that of the VPC endpoint service.
Service Category
There are two options: Cloud services or Find a service by name.
- Cloud services: The target VPC endpoint service is a cloud service.
- Find a service by name: The target VPC endpoint service is a private service of your own.
Example: Find a service by name
VPC Endpoint Service Name
This parameter is available only when you select Find a service by name for Service Category.
Enter the VPC endpoint service name recorded in step 8 and click Verify.
- If Service name found is displayed, proceed with subsequent operations.
- If Service name not found is displayed, check whether the region is the same as that of the connected VPC endpoint service or whether the entered service name is correct.
Private Domain Name
If you want to access a VPC endpoint using a domain name, select Create a Private Domain Name when creating a VPC endpoint. After the VPC endpoint is created, you can access it using the domain name.
- For the gateway type, this parameter is unavailable.
- For the interface type, this parameter is optional.
VPC
Specifies the VPC where the VPC endpoint is located.
Subnet
Specifies the subnet where the VPC endpoint is located.
Tag
This parameter is optional.
Specifies the VPC endpoint tag, which consists of a key and a value. You can add a maximum of 10 tags to each VPC endpoint.
Tag keys and values must meet requirements listed in Table 2.
Table 2 Tag requirements for VPC endpoints Parameter
Requirement
Tag key
- Cannot be left blank.
- Must be unique for each resource.
- Can contain a maximum of 36 Unicode characters.
- Cannot start or end with a space or contain special characters =*<>\,|/
Tag value
- Can contain a maximum of 43 Unicode characters.
- Confirm the specifications and click Create Now.
- If all of the specifications are correct, click Submit.
- If any of the specifications are incorrect, click Previous to return to the previous page and modify the parameters as needed, and click Submit.
- Manage the connection of the VPC endpoint.
If the status of the VPC endpoint changes to Accepted, the VPC endpoint is connected to the required VPC endpoint service. If the status is Pending acceptance, connection approval is enabled for the endpoint service, ask the owner of the endpoint service to perform the following operations:
- In the navigation pane on the left, choose VPC Endpoint > VPC Endpoint Services.
- In the VPC endpoint service list, locate the target VPC endpoint service and click its name.
- On the displayed page, select the Connection Management tab.
- If you allow a VPC endpoint to connect to this VPC endpoint service, locate the target VPC endpoint and click Accept in the Operation column.
- If you refuse a VPC endpoint from connecting to this VPC endpoint service, click Reject in the Operation column.
- Go back to the VPC endpoint list and check whether the status of the target VPC endpoint changes to Accepted. If yes, the VPC endpoint is connected to the VPC endpoint service.
- In the VPC endpoint list, click
before the target VPC endpoint to view its details.
After a VPC endpoint is created, a private IP address is assigned together with a private domain name if you select Create a Private Domain Name.
You can use the private IP address or private domain name to access the VPC endpoint service.
Configuration Verification
Log in to an ECS in VPC 1 remotely and access the VPC endpoint using its private IP address or private domain name.
