- What's New
- Function Overview
- Billing
- Getting Started
User Guide
VPC Endpoint Services
- VPC Endpoint Service Overview
- Creating a VPC Endpoint Service
- Viewing a VPC Endpoint Service
- Deleting a VPC Endpoint Service
- Managing Connections of a VPC Endpoint Service
- Managing Whitelist Records of a VPC Endpoint Service
- Managing Port Mappings of a VPC Endpoint Service
- Managing Tags of a VPC Endpoint Service
- VPC Endpoints
- Accessing OBS
- Using Cloud Eye to Monitor VPC Endpoints
- Using CTS to Audit VPC Endpoints
- Permissions Management
- Quotas
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Version Management
- Querying VPC Endpoint Services
- Querying Details of a VPC Endpoint Service
- Modifying a VPC Endpoint Service
- Querying Connections to a VPC Endpoint Service
- Accepting or Rejecting a VPC Endpoint
- Querying Whitelist Records of a VPC Endpoint Service
- Batch Adding or Deleting Whitelist Records of a VPC Endpoint Service
- Querying Public VPC Endpoint Services
- Querying Basic Information About a VPC Endpoint Service
- Changing the Name of a VPC Endpoint Service
- Updating Descriptions of VPC Endpoint Connections
- Batch Adding Whitelist Records of a VPC Endpoint Service
- Batch Deleting Whitelist Records of a VPC Endpoint Service
- Updating the Description of a Whitelist Record of a VPC Endpoint Service
- VPC Endpoints
- Resource Quotas
- Tags
- Application Examples
- Appendix
- SDK Reference
- FAQs
More Documents
- Getting Started
- Viewing Summary of a VPC Endpoint Service
- Viewing Port Mappings of a VPC Endpoint Service
- VPC Endpoints
- Permission Management
- FAQs
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
APIs for Managing VPC Endpoint Services
- Querying Connections of a VPC Endpoint Service
- Querying the Whitelist Records of a VPC Endpoint Service
- APIs for Managing VPC Endpoints
- Resource Quota
- Tag Function
- Appendix
- Change History
User Guide (Paris Region)
Getting Started
- Operation Guide
- Configuring a VPC Endpoint for Communications Across VPCs of the Same Domain
- Configuring a VPC Endpoint for Communications Across VPCs of Different Domains
- Configuring a VPC Endpoint for Accessing the Private IP Address of OBS over Private Networks
- Configuring a VPC Endpoint for Accessing the Public IP Address of OBS over Public Networks
- Viewing the Summary of a VPC Endpoint Service
- VPC Endpoints
- Quotas
- FAQ
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Querying Details About a VPC Endpoint Service
- Resource Quota
- Tag Function
- Appendix
- Change History
- Getting Started
- VPC Endpoints
- Quotas
- FAQ
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Tag Function
- Appendix
- Change History
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Appendix
- Change History
A VPC endpoint service is a cloud service or a private service that can be accessed through a VPC endpoint.
- Gateway VPC endpoint services are created only for cloud services.
- Interface VPC endpoint services can be created for both cloud services and your private services. All VPC endpoint services for cloud services are created by default while those for private services need to be created by users themselves.
Gateway VPC Endpoint Services
Gateway endpoint services are configured from cloud services by the system. You do not have the permission to configure such services but can select them when creating a VPC endpoint.
Supported cloud services vary in different regions. For details, see the list of services that can be configured on the management console.
VPC Endpoint Service |
Category |
Type |
Example |
Description |
OBS |
Cloud service |
Gateway |
None |
Access OBS using its private address. |
Interface VPC Endpoint Services
Interface VPC endpoint services are mainly configured from:
- Cloud services. You do not have the permission to configure such endpoint services, but can select them when they create a VPC endpoint.
- Your private services
Category |
Type |
Example |
Description |
DNS |
Cloud service |
Interface |
None |
VPC endpoint services enable you to access DNS over private networks. |
Load balancer |
Users' private service |
Interface |
None |
Select a load balancer as the backend resource if your services receive high traffic and demand high reliability and disaster recovery (DR) performance. |
ECS |
Interface |
None |
VPC endpoint services work as servers. |
