Help Center/
      Virtual Private Cloud/
         User Guide (ME-Abu Dhabi Region)/
        VPC and Subnet/
        Subnet/
      Viewing IP Addresses in a Subnet
        Updated on 2024-04-18 GMT+08:00
   A subnet is an IP address range in a VPC. This section describes how to view the used IP addresses in a subnet.
 - Virtual IP addresses
 - Private IP addresses
- Used by the subnet itself, such as the gateway, DHCP, and system interface.
 - Used by cloud resources, such as ECSs, load balancers, and RDS instances.
Notes and Constraints
- A subnet cannot be deleted if its IP addresses are used by cloud resources.
 - A subnet can be deleted if its IP addresses are used by itself.
 - Click
 in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
 - In the navigation pane on the left, choose Virtual Private Cloud > Subnets.
The Subnets page is displayed.
 - Locate the target subnet and click its name.
 - Click the IP Addresses tab to view the IP addresses in the subnet.
- In the virtual IP address list, you can view the virtual IP addresses assigned from the subnet.
 - In the private IP address list in the lower part of the page, you can view the private IP addresses and the resources that use the IP addresses of the subnet.
Follow-up Operations
If you want to view and delete the resources in a subnet, refer to Why Can't I Delete My VPCs and Subnets?
   Parent topic: Subnet
