Help Center/
      Virtual Private Cloud/
         User Guide (ME-Abu Dhabi Region)/
        VPC and Subnet/
        VPC/
      Viewing a VPC Topology
        Updated on 2024-04-18 GMT+08:00
This section describes how to view the topology of a VPC. The topology displays the subnets in a VPC and the ECSs in the subnets.
- Click
 in the upper left corner and select the desired region and project. - Click
 in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
 - In the VPC list, click the name of the VPC for which the topology is to be viewed.
 - Click the Topology tab to view the VPC topology.
The topology displays the subnets in the VPC and the ECSs in the subnets.
You can also perform the following operations on subnets and ECSs in the topology:- Modify or delete a subnet.
 - Add an ECS to a subnet, bind an EIP to the ECS, and change the security group of the ECS.
   Parent topic: VPC
