Modifying a Route
Updated on 2024-04-18 GMT+08:00
This section describes how to modify a custom route in a route table.
Notes and Constraints
  • System routes cannot be modified.
  • When you create a VPC endpoint, VPN or Direct Connect connection, the default route table automatically delivers a route that cannot be deleted or modified.
  • Routes with the next hop type of cloud container cannot be modified or deleted.
  • Routes with the next hop type of VPC endpoint cannot be modified or deleted.
  1. Click in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
  2. In the navigation pane on the left, choose Virtual Private Cloud > Route Tables.
  3. In the route table list, click the name of the target route table.
  4. Locate the row that contains the route to be modified and click Modify in the Operation column.
  5. Modify the route information in the displayed dialog box.
    Table 1 Parameter descriptions
    Example Value
    Destination
    Mandatory
    Enter the destination of the route. You can enter a single IP address or an IP address range in CIDR notation.
    NOTICE:
    • The destination of each route in a route table must be unique.
    • If an IP address group contains an IP address range in the format of Start IP address-End IP address, the IP address group is not supported.
      For example, an IP address group cannot contain 192.168.0.1-192.168.0.62. You need to change 192.168.0.1-192.168.0.62 to 192.168.0.0/26.
    IPv4: 192.168.0.0/16
    Next Hop Type
    Mandatory
    Set the type of the next hop.
    When you add or modify a custom route in a default route table, the next hop type of the route cannot be set to VPN gateway or Direct Connect gateway.
    VPC peering connection
    Next Hop
    Mandatory
    Set the next hop. The resources in the drop-down list box are displayed based on the selected next hop type.
    peer-AB
    Optional
    Enter the description of the route in the text box as required.
  6. Click OK.
