Step 3: Create a Security Group
A security group consists of inbound and outbound rules. You can add security group rules to allow or deny the traffic to reach and leave the instances (such as ECSs) in the security group.
When creating an instance (for example, an ECS), you must associate it with a security group. If no security group has been created yet, a default security group will be created and associated with the instance. You can also create a security group and add inbound and outbound rules to allow specific traffic.
- Click
in the upper left corner and select the desired region and project. - Click
in the upper left corner and choose Network > Virtual Private Cloud.
The Virtual Private Cloud page is displayed.
- In the navigation pane on the left, choose Access Control > Security Groups.
The security group list is displayed.
- In the upper right corner, click Create Security Group.
The Create Security Group page is displayed.
- Configure the parameters as prompted.
Figure 1 Create Security Group
Table 1 Parameter description Parameter
Example Value
Name
Mandatory
Enter the security group name.
The security group name can contain a maximum of 64 characters, which may consist of letters, digits, underscores (_), hyphens (-), and periods (.). The name cannot contain spaces.
NOTE:You can change the security group name after a security group is created. It is recommended that you give each security group a different name.
sg-AB
Enterprise Project
Mandatory
When creating a security group, you can add the security group to an enabled enterprise project.
An enterprise project facilitates project-level management and grouping of cloud resources and users. The name of the default project is default.
For details about creating and managing enterprise projects, see the Enterprise Management User Guide.
default
Template
Mandatory
The system provides several security group templates for you to create a security group. A security group template has preconfigured inbound and outbound rules. You can select a template based on your service requirements.
Table 1 describes the security group templates.
General-purpose web server
Optional
Supplementary information about the security group.
The security group description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
N/A
- Confirm the inbound and outbound rules of the template and click OK.
