Deleting a Security Group Rule
If you no longer need a security group rule to control the traffic to and from the instances in a security group, you can delete it.
Notes and Constraints
Note that deleting a security group rule may interrupt your services or cause network security risks.
Security group rules are like a whitelist. If there are no rules that allow or deny some traffic, the security group denies all traffic to or from the instances in the security group.
- Click
 in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
 - In the navigation pane on the left, choose Access Control > Security Groups.
The security group list is displayed.
 - In the security group list, click the name of the security group.
 - Click the Inbound Rules or Outbound Rules tab as required.
The security group rule list is displayed.
 - In the security group rule list:
- To delete a single security group rule, locate the row that contains the rule and click Delete in the Operation column.
 - To delete multiple security group rules, select multiple security group rules and click Delete in the upper left corner of the rule list.
 - Click Yes.
