Help Center/ Virtual Private Cloud/ User Guide (ME-Abu Dhabi Region)/ Access Control/ Security Group/ Managing Security Group Rules/ Replicating a Security Group Rule
Updated on 2024-04-18 GMT+08:00
You can replicate an existing security group rule and modify it to quickly generate a new rule.
- Click
in the upper left corner and choose Network > Virtual Private Cloud. The Virtual Private Cloud page is displayed.
- In the security group list, click the name of the security group.
- Click the Inbound Rules or Outbound Rules tab as required.
The security group rule list is displayed.
- Locate the row that contains the rule and click Replicate in the Operation column.
The Replicate Inbound Rule dialog box is displayed.
- Modify the security group rule information as prompted and click OK.
Parent topic: Managing Security Group Rules
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
