Application Scenarios
Dedicated Networks on Cloud
Each VPC represents a private network and is logically isolated from other VPCs. You can deploy your service system in a VPC so it will have a private network environment on the cloud. If you have multiple service systems, for example, a production system and a test system, you can deploy them in two different VPCs to keep them isolated. If you want to establish communication between these two VPCs, you can create a VPC peering connection to link them.
Related Services
ECS
