VPC Peering Connection Usage Examples
Updated on 2024-04-18 GMT+08:00
A VPC peering connection is a networking connection between two VPCs in the same region and enables them to communicate. Table 1 lists different scenarios of using VPC peering connections.
Table 1 VPC peering connection usage examples
Location
CIDR Block
Usage Example
  • VPC CIDR blocks do not overlap.
  • Subnet CIDR blocks of VPCs do not overlap.
You can create VPC peering connections to connect entire CIDR blocks of VPCs. Then, all resources in the VPCs can communicate with each other.
  • VPC CIDR blocks overlap.
  • Some subnet CIDR blocks overlap.
You can create VPC peering connections to connect specific subnets or ECSs from different VPCs.
  • To connect specific subnets from two VPCs, the subnet CIDR blocks cannot overlap.
  • To connect specific ECSs from two VPCs, each ECS must have a unique private IP address.
  • All subnet CIDR blocks overlap.
VPC peering connections are not usable.
Peering Two or More VPCs
  • Two VPCs peered together: Figure 1 shows the networking diagram of a VPC peering connection that connects VPC-A and VPC-B.
    Figure 1 Networking diagram (IPv4)
    Table 2 Peering relationships (IPv4)
    Peering Relationship
    Peering Connection Name
    Local VPC
    Peer VPC
    VPC-A is peered with VPC-B.
    Peering-AB
    VPC-A
    VPC-B
    Table 3 VPC route tables (IPv4)
    Route Table
    Destination
    Next Hop
    Route Type
    rtb-VPC-A
    10.0.0.0/16
    Peering-AB
    Custom
    Add a route with the CIDR block of VPC-B as the destination and Peering-AB as the next hop.
    rtb-VPC-B
    172.16.0.0/16
    Peering-AB
    Custom
    Add a route with the CIDR block of VPC-A as the destination and Peering-AB as the next hop.
  • Multiple VPCs peered together: Figure 2 shows the networking diagram of VPC peering connections that connect VPC-A, VPC-B, and VPC-C.
    Figure 2 Networking diagram (IPv4)
    Table 4 Peering relationships (IPv4)
    Local VPC
    Peer VPC
    Peering-AB
    VPC-A
    VPC-B
    VPC-A is peered with VPC-C.
    Peering-AC
    VPC-A
    VPC-C
    VPC-B is peered with VPC-C.
    Peering-BC
    VPC-B
    VPC-C
    Table 5 VPC route tables (IPv4)
    Route Table
    Destination
    Next Hop
    Route Type
    rtb-VPC-A
    10.0.0.0/16
    Peering-AB
    Custom
    192.168.0.0/16
    Peering-AC
    Custom
    Add a route with the CIDR block of VPC-C as the destination and Peering-AC as the next hop.
    rtb-VPC-B
    172.16.0.0/16
    Peering-AB
    Custom
    192.168.0.0/16
    Peering-BC
    Custom
    Add a route with the CIDR block of VPC-C as the destination and Peering-BC as the next hop.
    rtb-VPC-C
    172.16.0.0/16
    Peering-AC
    Custom
    Add a route with the CIDR block of VPC-A as the destination and Peering-AC as the next hop.
    10.0.0.0/16
    Peering-BC
    Custom
    Add a route with the CIDR block of VPC-B as the destination and Peering-BC as the next hop.
Peering One Central VPC with Multiple VPCs
Figure 3 shows the networking diagram of VPC peering connections that connect VPC-B, VPC-C, VPC-D, VPC-E, VPC-F, VPC-G, and central VPC-A.
Figure 3 Networking diagram (IPv4)
Table 6 Peering relationships (IPv4)
Local VPC
Peer VPC
Peering-AB
VPC-A
VPC-B
Peering-AC
VPC-A
VPC-C
VPC-A is peered with VPC-D.
Peering-AD
VPC-A
VPC-D
VPC-A is peered with VPC-E.
Peering-AE
VPC-A
VPC-E
VPC-A is peered with VPC-F.
Peering-AF
VPC-A
VPC-F
VPC-A is peered with VPC-G.
Peering-AG
VPC-A
VPC-G
Table 7 VPC route table details (IPv4)
Route Table
Destination
Next Hop
Route Type
rtb-VPC-A
10.0.0.0/16
Peering-AB
Custom
192.168.0.0/16
Peering-AC
Custom
10.2.0.0/16
Peering-AD
Custom
Add a route with the CIDR block of VPC-D as the destination and Peering-AD as the next hop.
10.3.0.0/16
Peering-AE
Custom
Add a route with the CIDR block of VPC-E as the destination and Peering-AE as the next hop.
172.17.0.0/16
Peering-AF
Custom
Add a route with the CIDR block of VPC-F as the destination and Peering-AF as the next hop.
10.4.0.0/16
Peering-AG
Custom
Add a route with the CIDR block of VPC-G as the destination and Peering-AG as the next hop.
rtb-VPC-B
172.16.0.0/16
Peering-AB
Custom
rtb-VPC-C
172.16.0.0/16
Peering-AC
Custom
rtb-VPC-D
172.16.0.0/16
Peering-AD
Custom
Add a route with the CIDR block of VPC-A as the destination and Peering-AD as the next hop.
rtb-VPC-E
172.16.0.0/16
Peering-AE
Custom
Add a route with the CIDR block of VPC-A as the destination and Peering-AE as the next hop.
rtb-VPC-F
172.16.0.0/16
Peering-AF
Custom
Add a route with the CIDR block of VPC-A as the destination and Peering-AF as the next hop.
rtb-VPC-G
172.16.0.0/16
Peering-AG
Custom
Add a route with the CIDR block of VPC-A as the destination and Peering-AG as the next hop.
Peering Two VPCs with Overlapping CIDR Blocks
As shown in Figure 4, VPC-A and VPC-B have overlapping CIDR blocks, and their Subnet-A01 and Subnet-B01 also have overlapping CIDR blocks. In this case, a VPC peering connection can connect their Subnet-A02 and Subnet-B02 that do not overlap with each other.
Figure 4 Networking diagram (IPv4)
Table 8 Peering relationships (IPv4)
Local VPC
Peer VPC
Peering-AB
VPC-A
VPC-B
Table 9 VPC route table details (IPv4)
Route Table
Destination
Next Hop
Route Type
rtb-VPC-A
10.0.2.0/24
Peering-AB
Custom
Add a route with the CIDR block of Subnet-B02 as the destination and Peering-AB as the next hop.
rtb-VPC-B
10.0.1.0/24
Peering-AB
Custom
Add a route with the CIDR block of Subnet-A02 as the destination and Peering-AB as the next hop.
Peering ECSs in a Central VPC with ECSs in Two Other VPCs
As shown in Figure 5, VPC-B and VPC-C have overlapping CIDR blocks, and their Subnet-B01 and Subnet-C01 have overlapping CIDR blocks. You can only create a VPC peering connection between ECSs.
  • Use VPC peering connection Peering-AB to connect ECSs in Subnet-B01 and Subnet-A01.
  • Use VPC peering connection Peering-AC to connect ECSs in Subnet-C01 and Subnet-A01.
Figure 5 Networking diagram (IPv4)
Table 10 Peering relationships (IPv4)
Local VPC
Peer VPC
ECS-A01-1 in VPC-A is peered with ECS-B01 in VPC-B.
Peering-AB
VPC-A
VPC-B
ECS-A01-2 in VPC-A is peered with ECS-C01 in VPC-C.
Peering-AC
VPC-A
VPC-C
Table 11 VPC route table details (IPv4)
Route Table
Destination
Next Hop
Route Type
rtb-VPC-A
10.0.0.139/32
Peering-AB
Custom
Add a route with the private IP address of ECS-B01 as the destination and Peering-AB as the next hop.
10.0.0.71/32
Peering-AC
Custom
Add a route with the private IP address of ECS-C01 as the destination and Peering-AC as the next hop.
rtb-VPC-B
172.16.0.111/32
Peering-AB
Custom
Add a route with the private IP address of ECS-A01-1 as the destination and Peering-AB as the next hop.
rtb-VPC-C
172.16.0.218/32
Peering-AC
Custom
Add a route with the private IP address of ECS-A01-2 as the destination and Peering-AC as the next hop.
Invalid VPC Peering Connections
If VPCs with the same CIDR block also include subnets that overlap, VPC peering connections are not usable. VPC-A and VPC-B have the same CIDR block and their subnets have the same CIDR block. If a VPC peering connection is created between VPC-A and VPC-B, traffic cannot be routed between them because there are routes with the same destination.
In the rtb-VPC-A route table, the custom route for routing traffic from VPC-A to VPC-B and the local route have overlapping destinations. The local route has a higher priority and traffic will be forwarded within VPC-A and cannot reach VPC-B.
Figure 6 Networking diagram (IPv4)
Table 12 VPC route table details
Route Table
Destination
Next Hop
Route Type
rtb-VPC-A
10.0.0.0/24
Local
System
Local routes are automatically added for communications within a VPC.
10.0.1.0/24
Local
System
10.0.0.0/16 (VPC-B)
Peering-AB
Custom
rtb-VPC-B
10.0.0.0/24
Local
System
10.0.1.0/24
Local
System
10.0.0.0/16 (VPC-A)
Peering-AB
Custom
