Creating a VPC Peering Connection with Another VPC in Your Account
If two VPCs from the same region cannot communicate with each other, you can use a VPC peering connection. This section describes how to create a VPC peering connection between two VPCs in the same account.
This following describes how to create a VPC peering connection between VPC-A and VPC-B in account A to enable communications between ECS-A01 and RDS-B01.
Procedure:
Step 1: Create a VPC Peering Connection
Step 2: Add Routes for the VPC Peering Connection
Step 3: Verify Network Connectivity
Notes and Constraints
- Only one VPC peering connection can be created between two VPCs at the same time.
- A VPC peering connection can only connect VPCs in the same region.
- If the local and peer VPCs have overlapping CIDR blocks, the VPC peering connection may not take effect.
You have two VPCs from the same account in the same region. If you want to create one, see Creating a VPC.
- Click
in the upper left corner and select the desired region and project. - Click
in the upper left corner and choose Network > Virtual Private Cloud.
The Virtual Private Cloud page is displayed.
- In the navigation pane on the left, choose Virtual Private Cloud > VPC Peering Connections.
The VPC peering connection list is displayed.
- In the upper right corner of the page, click Create VPC Peering Connection.
The Create VPC Peering Connection dialog box is displayed.
- Configure the parameters as prompted.
For details, see Table 1.
Figure 2 Create VPC Peering Connection
Table 1 Parameters for creating a VPC peering connection Parameter
Example Value
VPC Peering Connection Name
Mandatory
Enter a name for the VPC peering connection.
The name can contain a maximum of 64 characters, including letters, digits, hyphens (-), and underscores (_).
peering-AB
Local VPC
Mandatory
VPC at one end of the VPC peering connection. You can select one from the drop-down list.
VPC-A
Local VPC CIDR Block
CIDR block of the selected local VPC
172.16.0.0/16
Account
Mandatory
- Options: My account and Another account
- Select My account.
My account
Peer Project
The system fills in the corresponding project by default because My account is set to Account.
For example, if VPC-A and VPC-B are in account A and region A, the system fills in the correspond project of account A in region A by default.
ab-cdef-1
Peer VPC
This parameter is mandatory if Account is set to My account.
VPC at the other end of the VPC peering connection. You can select one from the drop-down list.
VPC-B
Peer VPC CIDR Block
CIDR block of the selected peer VPC
If the local and peer VPCs have overlapping CIDR blocks, the VPC peering connection may not take effect. For details, see VPC Peering Connection Usage Examples.
172.17.0.0/16
- Click OK.
A dialog box for adding routes is displayed.
- In the displayed dialog box, click Add Now. On the displayed Local Routes page, go to Step 2: Add Routes for the VPC Peering Connection to add a route.
To enable communications between VPCs connected by a VPC peering connection, you need to add forward and return routes to the route tables of the VPCs. For details, see VPC Peering Connection Usage Examples.
- Add routes to the route table of the local VPC:
- On the Local Routes tab of the VPC peering connection, click the Route Tables hyperlink.
The Summary tab of the default route table for the local VPC is displayed.
Figure 3 Hyperlink to route table-Local VPC
- Click Add Route.
Table 2 describes the route parameters.
Table 2 Parameter description Parameter
Example Value
Destination
The peer VPC CIDR block, subnet CIDR block, or ECS IP address. For details, see VPC Peering Connection Usage Examples.
VPC-B CIDR block: 172.17.0.0/16
Next Hop Type
The next hop type. Select VPC peering connection.
Next Hop
The next hop address. Select the name of the current VPC peering connection.
peering-AB
Supplementary information about the route. This parameter is optional.
The route description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
- Click OK.
You can view the route in the route list.
Figure 4 Route for the local VPC
- Add routes to the route table of the peer VPC:
- On the Peer Routes tab of the VPC peering connection, click the Route Tables hyperlink.
The Summary tab of the default route table for the peer VPC is displayed.
Figure 5 Hyperlink to route table-Peer VPC
- Click Add Route.
Table 3 describes the route parameters.
Table 3 Parameter description Parameter
Example Value
Destination
The local VPC CIDR block, subnet CIDR block, or ECS IP address. For details, see VPC Peering Connection Usage Examples.
VPC-A CIDR block: 172.16.0.0/16
Next Hop Type
Next Hop
peering-AB
- Click OK.
Figure 6 Route for the peer VPC
- Log in to ECS-A01 in the local VPC.
- Check whether ECS-A01 can communicate with RDS-B01.
Example command:
ping 172.17.0.21
If information similar to the following is displayed, ECS-A01 and RDS-B01 can communicate with each other, and the VPC peering connection between VPC-A and VPC-B is successfully created.[root@ecs-A02 ~]# ping 172.17.0.21 PING 172.17.0.21 (172.17.0.21) 56(84) bytes of data. 64 bytes from 172.17.0.21: icmp_seq=1 ttl=64 time=0.849 ms 64 bytes from 172.17.0.21: icmp_seq=2 ttl=64 time=0.455 ms 64 bytes from 172.17.0.21: icmp_seq=3 ttl=64 time=0.385 ms 64 bytes from 172.17.0.21: icmp_seq=4 ttl=64 time=0.372 ms ... --- 172.17.0.21 ping statistics ---
- In this example, ECS-A01 and RDS-B01 are in the same security group. If the instances in different security groups, you need to add inbound rules to allow access from the peer security group. For details, see Enabling Communications Between Instances in Different Security Groups.
- If VPCs connected by a VPC peering connection cannot communicate with each other, refer to Why Did Communication Fail Between VPCs That Were Connected by a VPC Peering Connection?.
