Adding a Security Group Rule
Updated on 2024-04-18 GMT+08:00
A security group consists of inbound and outbound rules. You can add security group rules to allow or deny the traffic to reach and leave the instances (such as ECSs) in the security group.
Precautions
  • Before configuring security group rules, you need to plan access policies for instances in the security group. For details about common security group rules, see Security Group Configuration Examples.
  • Add as fewer rules as possible. Security Group Constraints lists the constraints on the number of rules in a security group.
  • After allowing traffic over a port in a security group rule, ensure that the port used by the instance is opened. For details, see Verifying Security Group Rules.
  • By default, instances in the same security group can communicate with each other. If instances in the same security group cannot communicate with each other, possible causes are as follows:
    • The inbound rules for communications between these instances are deleted. Table 1 shows the inbound rules.
      Table 1 Inbound rules for communication between instances
      Direction
      Type
      Protocol & Port
      Source/Destination
      Inbound
      IPv4
      All
      Source: current security group (Sg-A)
    • Different VPCs cannot communicate with each other. The instances belong to the same security group but different VPCs.
      You can use VPC peering connections to connect VPCs in different regions.
Adding Rules to a Security Group
  2. Click in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
  3. In the navigation pane on the left, choose Access Control > Security Groups.
    The security group list is displayed.
  4. Locate the row that contains the target security group, and click Manage Rule in the Operation column.
    The page for configuring security group rules is displayed.
  5. On the Inbound Rules tab, click Add Rule.
    The Add Inbound Rule dialog box is displayed.
  6. Configure required parameters.
    You can click + to add more inbound rules.
    Table 2 Inbound rule parameter description
    Example Value
    Type
    Source IP address version. You can select:
    • IPv4
    • IPv6
    IPv4
    Protocol & Port
    The network protocol used to match traffic in a security group rule. The value can be All, TCP, UDP, GRE, and ICMP.
    TCP
    Destination port used to match traffic in a security group rule. The value can be from 1 to 65535.
    Inbound rules control incoming traffic over specific ports to instances in the security group.
    22, or 22-30
    Source
    Source of the security group rule. The value can be an IP address or a security group to allow access from IP addresses or instances in the security group. If you select IP address for Source, you can enter multiple IP addresses in the same IP address box. Each IP address represents a different security group rule.
    • IP address:
      • Single IP address: 192.168.10.10/32
      • All IP addresses: 0.0.0.0/0
      • IP address range: 192.168.1.0/24
    If the source is a security group, this rule will apply to all instances associated with the selected security group.
    0.0.0.0/0
    Supplementary information about the security group rule. This parameter is optional.
    The security group rule description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
    N/A
  7. Click OK.
    The inbound rule list is displayed.
  8. On the Outbound Rules tab, click Add Rule.
    The Add Outbound Rule dialog box is displayed.
  9. Configure required parameters.
    You can click + to add more outbound rules.
    Table 3 Outbound rule parameter description
    Example Value
    Type
    Destination IP address version. You can select:
    • IPv4
    • IPv6
    IPv4
    Protocol & Port
    TCP
    Outbound rules control outgoing traffic over specific ports from instances in the security group.
    22, or 22-30
    Destination
    Destination of the security group rule. The value can be an IP address or a security group to allow access to IP addresses or instances in the security group. For example: If you select IP address for Destination, you can enter multiple IP addresses in the same IP address box. Each IP address represents a different security group rule.
    • IP address:
    0.0.0.0/0
    N/A
  10. Click OK.
    The outbound rule list is displayed.
After allowing traffic over a port in a security group rule, you need to ensure that the port used by the instance is also opened.
For example, if you have deployed a website on an ECS and want users to access your website through HTTP (80), you need to add an inbound rule to the ECS security group to allow access over the port. Table 4 shows the rule.
Table 4 Security group rule
Direction
Type
Protocol & Port
Source
Inbound
IPv4
TCP: 80
IP address: 0.0.0.0/0
After adding the security group rule, perform the following operations to check whether the ECS port is opened and whether the rule is applied:
  1. Log in to the ECS and check whether the ECS port is opened.
    • Checking the port of a Linux server
      Run the following command to check whether TCP port 80 is being listened on:
      netstat -an | grep 80
      If the following figure is displayed, TCP port 80 is enabled.
      Figure 1 Command output for the Linux ECS
    • Checking the port of a Windows server
      1. Choose Start > Run. Type cmd to open the Command Prompt.
      2. Run the following command to check whether TCP port 80 is being listened on:
        netstat -an | findstr 80
        Figure 2 Command output for the Windows ECS
  2. Enter http://ECS EIP in the address box of the browser and press Enter.
    If the requested page can be accessed, the security group rule has taken effect.
