Enabling or Disabling VPC Flow Log
After a VPC flow log is created, the VPC flow log is automatically enabled. If you do not need to record flow log data, you can disable the corresponding VPC flow log. A disabled VPC flow log can be enabled again.
Notes and Constraints
- After a VPC flow log is enabled, the system starts to collect flow logs in the next log collection period.
 - After a VPC flow log is disabled, the system stops collecting flow logs in the next log collection period. Generated flow logs will still be reported.
- Click
 in the upper left corner and select the desired region and project.
- Click
 in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
- In the navigation pane on the left, choose VPC Flow Logs.
 - Locate the VPC flow log to be enabled or disabled, and click Enable or Disable in the Operation column.
 - Click Yes.
