Creating a VPC Flow Log
A VPC flow log records information about the traffic going to and from a VPC.
Ensure that the following operations have been performed on the LTS console:
- Create a log group.
- Create a log stream.
For more information about the LTS service, see the Log Tank Service User Guide.
- Click
in the upper left corner and select the region and project.
- Click
in the upper left corner and choose Network > Virtual Private Cloud. The Virtual Private Cloud page is displayed.
- In the navigation pane on the left, choose VPC Flow Logs.
- In the upper right corner, click Create VPC Flow Log. On the displayed page, configure parameters as prompted.
Table 1 Parameter descriptions Parameter
Example Value
Name
The VPC flow log name. The name:- Can contain 1 to 64 characters.
- Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
flowlog-495d
Resource Type
Type of the resource whose traffic is to be logged. The options can be one of the following:- NIC
- Subnet
- VPC
NIC
Resource
The specific resource whose traffic is to be logged.
NOTE:We recommend that you select an ECS that is in the running status. If an ECS in the stopped status is selected, restart the ECS after creating the VPC flow log for accurately recording the information about the traffic going to and from the network interface of the ECS.
N/A
Filter
- All traffic: Both accepted and rejected traffic of the specified resource will be logged.
- Accepted traffic: Only accepted traffic of the specified resource will be logged. Accepted traffic refers to the traffic allowed by the security group and network ACL.
- Rejected traffic: Only rejected traffic of the specified resource will be logged. Rejected traffic refers to the traffic denied by the security group and network ACL.
All
Log Group
The log group created in LTS.
lts-group-abc
Log Stream
The log stream created in LTS.
lts-topic-abc
Supplementary information about the VPC flow log. This parameter is optional.
The VPC flow log description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
N/A
Only two flow logs, each with a different filter, can be created for a single resource under the same log group and log stream. Each VPC flow log must be unique.
- After setting the parameters, click OK.
Return to the VPC flow log list and check the new VPC flow log.
