- What's new
- Function Overview
- Getting Started
User Guide
- Introduction
- Permissions Management
- Basics of the Container Engine
Image Management
- Uploading an Image Through a Container Engine Client (Recommended)
- Obtaining a Long-Term Valid Login Command
- Uploading an Image Through SWR Console
- Pulling an Image
- Setting Image Attributes
- Sharing a Private Image
- Adding a Trigger
- Adding an Image Retention Policy
- Configuring Automatic Image Synchronization Between Regions
- Image Center
- Organization Management
- User Permissions
- Auditing
- Change History
- Best Practices
API Reference
- Before You Start
- Calling APIs
- API Overview
API
- Image Repository Management
- Image Tag Management
- Image Sharing Management
- API Versions
- Organization Permission Management
- Image Permission Management
- Image Synchronization Management
- Trigger Management
- Image Retention Policy Management
- Temporary Login Command
- Quota Management
- Other
- Example Applications
- Appendixes
- SDK Reference
- General FAQs
- Login Issues
- Synchronizing Images
- Pushing an Image
- Pulling an Image
Troubleshooting
- Why Does the Login Command Fail to Be Executed?
- Why Does an Image Fail to Be Pushed Through a Container Engine Client?
- Why Does an Image Fail to Be Uploaded Through SWR Console?
- Why Does the docker pull Command Fail to Be Executed?
- What Should I Do If Images Cannot Be Downloaded from Private Networks?
- What Do I Do If an Error Occurs When I Call an API?
Other FAQs
- Why Does a CCE Workload Cannot Pull an Image from SWR and a Message "Not Logged In" Is Displayed?
- How Many Tenants Can I Share an SWR Private Image With?
- Why Is an Image Pushed Using a Container Engine Client to SWR Different in Size From One Uploaded Through the SWR Console?
- Can I Pull Images on the SWR Console to a Local PC?
- Videos
- Glossary
More Documents
- User Guide
- API Reference
- User Guide (Paris Regions)
- API Reference (Paris Regions)
- User Guide (Kuala Lumpur Region)
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Overview
- Basics of Docker
Image Management
- Pushing an Image Through a Container Engine Client
- Obtaining a Long-Term Valid Docker Login Command
- Obtaining a Long-Term Valid containerd Pull/Push Command
- Uploading an Image Through the SWR Console
- Pulling an Image
- Sharing Private Images
- Adding a Trigger
- User Permissions
- FAQs
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- API
- Appendixes
On this page
Notes and Constraints
Quotas
Quotas are imposed on the number of organizations a user can create. Table 1 lists the quotas imposed by SWR.
Requirements on Images to Upload
- If you use the container engine client to push images to SWR, each image layer cannot exceed 10 GB.
- If you use the SWR console to upload images, a maximum of 10 files can be uploaded at a time. The size of a single file (including the decompressed files) cannot exceed 2 GB.
Parent topic: Service Overview
