Introduction
SoftWare Repository for Container (SWR) allows you to easily manage the full lifecycle of container images and facilitates secure deployment of images for your applications.
SWR can either work with CCE or be used as an independent container image repository.
Features
- Full lifecycle management of images
SWR manages the whole lifecycle of your container images, including push, pull, and deletion.
- Private image repository and access control
Private image repository and fine-grained permission management allow you to grant different access permissions, namely, read, write, and edit, to different users.
- Large scale image distribution acceleration
SWR uses the image pull acceleration technology to ensure faster image pull for CCE clusters in high concurrency scenarios.
- Automatic deployment update through triggers
Image deployment can be triggered automatically upon image update. Simply set a trigger to the desired image. Every time the image is updated, the application deployed with this image will be automatically updated.
Accessing SWR
The cloud platform provides a web-based management console and HTTPS-based APIs through which you can access the SWR service.
