- What's new
- Function Overview
- Getting Started
User Guide
- Introduction
- Permissions Management
- Basics of the Container Engine
Image Management
- Uploading an Image Through a Container Engine Client (Recommended)
- Obtaining a Long-Term Valid Login Command
- Uploading an Image Through SWR Console
- Pulling an Image
- Setting Image Attributes
- Sharing a Private Image
- Adding a Trigger
- Adding an Image Retention Policy
- Configuring Automatic Image Synchronization Between Regions
- Image Center
- Organization Management
- User Permissions
- Auditing
- Change History
- Best Practices
API Reference
- Before You Start
- Calling APIs
- API Overview
API
- Image Repository Management
- Image Tag Management
- Image Sharing Management
- API Versions
- Organization Permission Management
- Image Permission Management
- Image Synchronization Management
- Trigger Management
- Image Retention Policy Management
- Temporary Login Command
- Quota Management
- Other
- Example Applications
- Appendixes
- SDK Reference
- General FAQs
- Login Issues
- Synchronizing Images
- Pushing an Image
- Pulling an Image
Troubleshooting
- Why Does the Login Command Fail to Be Executed?
- Why Does an Image Fail to Be Pushed Through a Container Engine Client?
- Why Does an Image Fail to Be Uploaded Through SWR Console?
- Why Does the docker pull Command Fail to Be Executed?
- What Should I Do If Images Cannot Be Downloaded from Private Networks?
- What Do I Do If an Error Occurs When I Call an API?
Other FAQs
- Why Does a CCE Workload Cannot Pull an Image from SWR and a Message "Not Logged In" Is Displayed?
- How Many Tenants Can I Share an SWR Private Image With?
- Why Is an Image Pushed Using a Container Engine Client to SWR Different in Size From One Uploaded Through the SWR Console?
- Can I Pull Images on the SWR Console to a Local PC?
- Videos
- Glossary
More Documents
- User Guide
- API Reference
- User Guide (Paris Regions)
- API Reference (Paris Regions)
- User Guide (Kuala Lumpur Region)
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Overview
- Basics of Docker
Image Management
- Pushing an Image Through a Container Engine Client
- Obtaining a Long-Term Valid Docker Login Command
- Obtaining a Long-Term Valid containerd Pull/Push Command
- Uploading an Image Through the SWR Console
- Pulling an Image
- Sharing Private Images
- Adding a Trigger
- User Permissions
- FAQs
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- API
- Appendixes
SWR Operations Supported by CTS
CTS records operations on cloud resources in your account. You can use the logs to perform security analysis, track resource changes, audit, and locate faults.
With CTS, you can record operations associated with SWR for future query, audit, and backtrack operations.
Key Operations Recorded by CTS
Operation |
Resource Type |
Trace Name |
Granting permissions for an organization |
usernamespaceauth |
createUserNamespaceAuth |
Modifying permissions for an organization |
usernamespaceauth |
updateUserNamespaceAuth |
Deleting permissions for an organization |
usernamespaceauth |
deleteUserNamespaceAuth |
Creating a software package |
package |
createPackage |
Modifying a software package |
package |
updatePackage |
Deleting a software package |
package |
deletePackage |
Creating a repository |
repository |
createRepository |
Modifying a repository |
repository |
updateRepository |
Deleting a repository |
repository |
deleteRepository |
Creating a version |
version |
createVersion |
Modify a version |
version |
updateVersion |
Deleting a version |
version |
deleteVersion |
Uploading an image package |
image |
uploadImagePackage |
Uploading a file |
file |
uploadFile |
Downloading a file |
file |
downloadFile |
Deleting a file |
file |
deleteFile |
Creating an organization |
usernamespace |
createUserNamespace |
Deleting an organization |
usernamespace |
deleteUserNamesapce |
Creating a trigger |
trigger |
createTrigger |
Modifying a trigger |
trigger |
updateTrigger |
Deleting a trigger |
trigger |
deleteTrigger |
Granting permissions for an image repository |
userrepositoryauth |
createUserRepositoryAuth |
Modifying permissions for an image repository |
updateUserRepositoryAuth |
Deleting permissions for an image repository |
deleteUserRepositoryAuth |
Creating an image repository |
imagerepository |
createImageRepository |
Modifying an image repository |
imagerepository |
updateImageRepository |
Deleting an image repository |
imagerepository |
deleteImageRepository |
Deleting an image tag |
imagetag |
deleteImageTag |
Generating a login command |
dockerlogincmd |
createDockerConfig |
Creating a shared image |
imagerepositoryaccessdomain |
createImageRepositoryAccessDomain |
Modifying a shared image |
updateImageRepositoryAccessDomain |
Deleting a shared image |
deleteImageRepositoryAccessDomain |
