- What's new
- Function Overview
- Getting Started
User Guide
- Introduction
- Permissions Management
- Basics of the Container Engine
Image Management
- Uploading an Image Through a Container Engine Client (Recommended)
- Obtaining a Long-Term Valid Login Command
- Uploading an Image Through SWR Console
- Pulling an Image
- Setting Image Attributes
- Sharing a Private Image
- Adding a Trigger
- Adding an Image Retention Policy
- Configuring Automatic Image Synchronization Between Regions
- Image Center
- Organization Management
- User Permissions
- Auditing
- Change History
- Best Practices
API Reference
- Before You Start
- Calling APIs
- API Overview
API
- Image Repository Management
- Image Tag Management
- Image Sharing Management
- API Versions
- Organization Permission Management
- Image Permission Management
- Image Synchronization Management
- Trigger Management
- Image Retention Policy Management
- Temporary Login Command
- Quota Management
- Other
- Example Applications
- Appendixes
- SDK Reference
- General FAQs
- Login Issues
- Synchronizing Images
- Pushing an Image
- Pulling an Image
Troubleshooting
- Why Does the Login Command Fail to Be Executed?
- Why Does an Image Fail to Be Pushed Through a Container Engine Client?
- Why Does an Image Fail to Be Uploaded Through SWR Console?
- Why Does the docker pull Command Fail to Be Executed?
- What Should I Do If Images Cannot Be Downloaded from Private Networks?
- What Do I Do If an Error Occurs When I Call an API?
Other FAQs
- Why Does a CCE Workload Cannot Pull an Image from SWR and a Message "Not Logged In" Is Displayed?
- How Many Tenants Can I Share an SWR Private Image With?
- Why Is an Image Pushed Using a Container Engine Client to SWR Different in Size From One Uploaded Through the SWR Console?
- Can I Pull Images on the SWR Console to a Local PC?
- Videos
- Glossary
More Documents
- User Guide
- API Reference
- User Guide (Paris Regions)
- API Reference (Paris Regions)
- User Guide (Kuala Lumpur Region)
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Overview
- Basics of Docker
Image Management
- Pushing an Image Through a Container Engine Client
- Obtaining a Long-Term Valid Docker Login Command
- Obtaining a Long-Term Valid containerd Pull/Push Command
- Uploading an Image Through the SWR Console
- Pulling an Image
- Sharing Private Images
- Adding a Trigger
- User Permissions
- FAQs
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- API
- Appendixes
You can share your private images with other accounts and grant the accounts permissions to pull the images.
A user under the account with which you shared the image can then log in to the SWR console to view the image by clicking My Images > Shared Images. On the tab page, the user can click the target image to check its detailed information, including the image tag and image pull command.
Notes and Constraints
- Only private images can be shared. Public images cannot be shared.
- Only users authorized to manage the private images can share images. The users with whom you share your images only have the read-only permission, which only allows them to pull the images.
- You can share images only with accounts in the same region. Cross-region image sharing is not supported.
- Log in to the SWR console.
- In the navigation pane, choose My Images and click the target image.
- On the details page, click the Sharing tab.
- Click Share Image. Set parameters based on Table 1, and click OK.
Figure 1 Sharing an image
Table 1 Sharing an image Parameter
Share With
Enter an account name with which you want to share the image.
Valid Until
Set a validity period. If you want the image to be permanently accessible to the account, select Permanently valid.
Enter a maximum of 1,000 characters.
Permission
Only the Pull permission is supported currently.
- To view all the images that you have shared, choose My Images in the navigation pane, click the Private Images tab, and select Display only shared images.
