Help Center/
SoftWare Repository for Container/
User Guide/
FAQs/
Other FAQs/
Why Does a CCE Workload Cannot Pull an Image from SWR and the Message Indicating "Not Logged In" Is Displayed?
Updated on 2024-04-19 GMT+08:00
If a CCE workload cannot pull an SWR image and the message indicating "Not logged in" is displayed, check whether the YAML file of the workload contains the imagePullSecrets field and whether the value of name is fixed to default-secret.
Example:
apiVersion: extensions/v1beta1 kind: Deployment metadata: name: nginx spec: replicas: 1 selector: matchLabels: app: nginx strategy: type: RollingUpdate template: metadata: labels: app: nginx spec: containers: - image: nginx imagePullPolicy: Always name: nginx imagePullSecrets: - name: default-secret
Parent topic: Other FAQs
