HTTP or HTTPS Message Format
When receiving HTTP or HTTPS messages sent by SMN, refer to the industry standards for the common name (CN) of the terminal certificate. Some special characters may cause HTTPS message sending failures.
This section describes the format of messages sent to HTTP or HTTPS endpoints. You can identify messages based on message types in the headers. HTTP/HTTPS message types include: subscription confirmation messages, notification messages, and subscription cancellation messages. POST is used for HTTP/HTTPS messages.
The header of an SMN HTTP/HTTPS message contains the following parameters: X-SMN-MESSAGE-TYPE, X-SMN-MESSAGE-ID, X-SMN-TOPIC-URN, and X-SMN-SUBSCRIPTION-URN.
Parameter |
Description |
X-SMN-MESSAGE-TYPE |
Indicates the message type, which can be:
X-SMN-MESSAGE-ID |
Indicates the unique message ID. |
X-SMN-TOPIC-URN |
Indicates the URN of the topic the message belongs to. |
X-SMN-SUBSCRIPTION-URN |
Identifies the subscription endpoint. This parameter is required only when messages are pushed over HTTP/HTTPS and when you cancel your HTTP/HTTPS subscriptions. |
The requirements for HTTP header fields are described as follows:
- According to section 3.2 in RFC 7230, header fields should be case insensitive.
- According to section 8.1.2 in RFC 7540, header fields in HTTP/2 should be lowercase.
- Custom HTTP header fields must comply with the above two requirements for SMN.
- You are advised to use case-insensitive letters to obtain HTTP header fields.
HTTP/HTTPS Subscription Confirmation Message Format
After you add an HTTP/HTTPS endpoint, SMN sends a subscription confirmation message to the subscriber. The message body is composed of JSON character strings. The subscriber must obtain the subscription URL (subscribe_url) to confirm the subscription. Table 2 describes the JSON field in detail.
Parameter |
Description |
type |
Indicates the message type, which is SubscriptionConfirmation. |
signature |
Indicates the signature information. The signature includes the message, message_id, subscribe_url, timestamp, topic_urn, and type fields. For details about signature verification, see Message Signature Verification. |
topic_urn |
message_id |
signature_version |
Indicates the signature version, which is V1. |
message |
Indicates the message content. |
subscribe_url |
Indicates the URL to be accessed for subscription confirmation. |
signing_cert_url |
Indicates the certificate URL for a message signature. It can be directly accessed without authentication. |
timestamp |
Indicates the time stamp when the message was initially sent. |
{ "signature": "ViE96uGbBkl+S8eWqgebi5KdmRht2U8+Rs88yuyMHq1k4h3jUkcDZ6HCqTqdpJ8nrLcdqETyyEiOQyTszJdU05z+LhfE8jerCCdSbL4zeInVkydHh0kcCRWmORye0/EuQ/gLC1UIXwvUsqbUCPnBRhNFXOeXMOPPCzK+d04xjy4QHd1H/bHxgsY3AlTe0gCFT068Zru7OK6w9aQaY44mXnN3OWGmBmoHyFab5TRXLSQNz/9u/Vj646cQMMaI0PPQ30QzGYD0MtzgDZi12m8jMTHAnMkTEcbLaEgaqmaoEnATSpEcspFKNXv2skwk7rsVakMOISpMH3+qC6RzhETA2A==", "topic_urn": "urn:smn:region01:0553db98c800d5192f9bc01232b89622:vpc_status_report_topic", "message_id": "d86c201092574e71a3ca85826652c58b", "signature_version": "v1", "type": "SubscriptionConfirmation", "message": "You are invited to subscribe to topic: urn:smn:region01:0553db98c800d5192f9bc01232b89622:vpc_status_report_topic. To confirm this subscription, please visit the subscribe_url included in this message. The subscribe_url is valid only within 48 hours.", "subscribe_url": "https://console.xxx.com/smn/subscription/unsubscribe?subscription_urn=urn:smn:region01:0553db98c800d5192f9bc01232b89622:vpc_status_report_topic:653e212a43884f7188ca656c537e31ce", "signing_cert_url": "https://console.xxx.com/smn/SMN_region01_b3974c411807498bb532b3cd6cd65d91.pem", "timestamp": "2019-08-12T22:40:56Z" }
HTTP/HTTPS Notification Message Format
After an HTTP/HTTPS subscriber confirms the subscription, the subscriber can receive notification messages published to the topic. The notification message body is composed of JSON character strings, which are described in Table 3.
Parameter |
Description |
type |
Indicates the message type, which is Notification. |
signature |
Indicates the signature information. The signature includes the message, message_id, subject, timestamp, topic_urn, and type fields. If the subject field is empty, the signature is not verified. For details about signature verification, see Message Signature Verification. |
subject |
Indicates the message subject. |
topic_urn |
message_id |
signature_version |
message |
unsubscribe_url |
Indicates the URL for canceling a subscription. |
signing_cert_url |
Indicates the certificate URL for generating the message signature. |
timestamp |
{ "signature": "ViE96uGbBkl+S8eWqgebi5KdmRht2U8+Rs88yuyMHq1k4h3jUkcDZ6HCqTqdpJ8nrLcdqETyyEiOQyTszJdU05z+LhfE8jerCCdSbL4zeInVkydHh0kcCRWmORye0/EuQ/gLC1UIXwvUsqbUCPnBRhNFXOeXMOPPCzK+d04xjy4QHd1H/bHxgsY3AlTe0gCFT068Zru7OK6w9aQaY44mXnN3OWGmBmoHyFab5TRXLSQNz/9u/Vj646cQMMaI0PPQ30QzGYD0MtzgDZi12m8jMTHAnMkTEcbLaEgaqmaoEnATSpEcspFKNXv2skwk7rsVakMOISpMH3+qC6RzhETA2A==", "topic_urn": "urn:smn:region01:0553db98c800d5192f9bc01232b89622:vpc_status_report_topic", "message_id": "d86c201092574e71a3ca85826652c58b", "signature_version": "v1", "type": "Notification", "message": "{\"enterpriseProjectId\": \"0\", \"eventTime\": \"2019-08-12 22:40:55.040632\", \"chargingMode\": \"postPaid\", \"cloudserviceType\": \"xxx.service.type.bandwidth\", \"eventType\": 1, \"regionId\": \"region01\", \"tenantId\": \"057eefe55400d2742f8cc0017870ceef\", \"resourceType\": \"xxx.resource.type.bandwidth\", \"resourceSpecCode\": \"19_bgp\", \"resourceSize\": 10, \"resourceId\": \"e091f1b1-08ef-4e2b-a27e-f85e4c19026a\", \"resouceSizeMeasureId\": 15, \"resourceName\": \"elbauto_2019_08_13_06_40_46\"}", "unsubscribe_url": "https://console.xxx.com/smn/subscription/unsubscribe?subscription_urn=urn:smn:region01:0553db98c800d5192f9bc01232b89622:vpc_status_report_topic:653e212a43884f7188ca656c537e31ce", "signing_cert_url": "https://console.xxx.com/smn/SMN_region01_b3974c411807498bb532b3cd6cd65d91.pem", "timestamp": "2019-08-12T22:40:56Z" }
HTTP/HTTPS Subscription Cancellation Message Format
After an HTTP/HTTPS subscription is canceled, the subscriber receives a subscription cancellation message sent by SMN. The message body is composed of JSON character strings, which are described in Table 4.
Parameter |
Description |
type |
Indicates the message type. Its value is UnsubscribeConfirmation. |
signature |
topic_urn |
message_id |
signature_version |
message |
subscribe_url |
Indicates the URL for a re-subscription. |
signing_cert_url |
timestamp |
{ "signature": "ViE96uGbBkl+S8eWqgebi5KdmRht2U8+Rs88yuyMHq1k4h3jUkcDZ6HCqTqdpJ8nrLcdqETyyEiOQyTszJdU05z+LhfE8jerCCdSbL4zeInVkydHh0kcCRWmORye0/EuQ/gLC1UIXwvUsqbUCPnBRhNFXOeXMOPPCzK+d04xjy4QHd1H/bHxgsY3AlTe0gCFT068Zru7OK6w9aQaY44mXnN3OWGmBmoHyFab5TRXLSQNz/9u/Vj646cQMMaI0PPQ30QzGYD0MtzgDZi12m8jMTHAnMkTEcbLaEgaqmaoEnATSpEcspFKNXv2skwk7rsVakMOISpMH3+qC6RzhETA2A==", "topic_urn": "urn:smn:region01:0553db98c800d5192f9bc01232b89622:vpc_status_report_topic", "message_id": "d86c201092574e71a3ca85826652c58b", "signature_version": "v1", "type": "UnsubscribeConfirmation", "message": "You are unsubscribed from topic: urn:smn:region01:0553db98c800d5192f9bc01232b89622:vpc_status_report_topic. To subscribe to this topic again, please visit the subscribe_url included in this message. The subscribe_url is valid only within 48 hours.", "subscribe_url": "https://console.xxx.com/smn/subscription/unsubscribe?subscription_urn=urn:smn:region01:0553db98c800d5192f9bc01232b89622:vpc_status_report_topic:653e212a43884f7188ca656c537e31ce", "signing_cert_url": "https://console.xxx.com/smn/SMN_region01_b3974c411807498bb532b3cd6cd65d91.pem", "timestamp": "2019-08-12T22:40:56Z" }
