- What's New
- Function Overview
- Getting Started
User Guide
- Topic Management
- Subscription Management
- Message Template Management
- SMN Operation Recording
- Cloud Eye Monitoring
- Logs
- Permissions Management
- Quotas
- Appendix
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs
- Examples
- Public Parameters
- Out-of-Date APIs
- Appendix
- SDK Reference
- What Are the Advantages of SMN?
- What Protocols Does SMN Support?
- How Is SMN Billed?
- What Are the Requirements for an SMN Topic Name?
- How Many Topics Can I Create?
- How Many Subscriptions Can Be Added to a Topic?
- How Many Messages Can Be Published to a Topic?
- How Many Message Templates Can I Create?
- What Are the Limitations on SMS Messages?
- Can I Add Subscriptions Using Multiple Protocols to a Topic?
- Can a Topic Creator Change Subscription Protocols in a Topic?
- Can I Change a Subscription Endpoint for a Topic?
- Can I Delete a Published Message?
- Does SMN Ensure That Messages Are Received by Subscription Endpoints?
- Will a Subscriber Receive the Same Message Multiple Times?
- Why Do Subscribers Fail to Receive Messages After I Publish Messages to a Topic?
- What Can I Do When Pictures in an Email Message Cannot Be Displayed?
- Does SMN Always Use the Same Phone Number or Sender Name to Send SMS Messages?
- How Do I Obtain My Account ID?
- How Does a DingTalk, Internal DingTalk, Lark, or WeCom Chatbot Obtain Subscription Endpoints?
- Videos
More Documents
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference
User Guide (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Overview
- Getting Started
- Topic Management
- Quotas
- Appendix
- Change History
- API Reference (Ankara Region)
On this page
Show all
Help Center/
Simple Message Notification/
User Guide (ME-Abu Dhabi Region)/
FAQs/
If you have verified that the subscription endpoints are normal, the most possible reason is that the subscribers have not confirmed their subscriptions or the confirmation messages and messages published have been blocked.
Check whether the message is blocked and processed as a junk message.
If the problem persists, contact technical support.
Parent topic: FAQs
