Help Center/ Scalable File Service/ User Guide (ME-Abu Dhabi Region)/ Troubleshooting/ Error Message "wrong fs type, bad option" Is Displayed During File System Mounting
Updated on 2025-11-07 GMT+08:00
Symptom
The message "wrong fs type, bad option" is displayed when you run the mount command to mount a file system to an ECS running Linux.
Possible Causes
An NFS client is not installed on the Linux ECS. That is, the nfs-utils software package is not installed before you execute the mount command.
Fault Diagnosis
Install the required nfs-utils software package.
Solution
  1. Log in to the ECS and check whether the nfs-utils package is installed. Run the following command. If no command output is displayed, the package is not installed.
    rpm -qa|grep nfs
    Figure 1 Checking whether the software package has been installed
  2. Run the following command to install the nfs-utils software package:
    yum -y install nfs-utils
    Figure 2 Executing the installation command
    Figure 3 Successful installation
  3. Run the mount command again to mount the file system to the ECS.
    mount -t nfs -o vers=3,timeo=600,noresvport,nolock Mount point Local path
  4. Run the following command to view the mounted file system:
    mount -l
    If the command output contains the following information, the file system has been mounted:
    example.com:/share-xxx on /local_path type nfs (rw,vers=3,timeo=600,nolock,addr=)
