Help Center/ Scalable File Service/ User Guide (ME-Abu Dhabi Region)/ Troubleshooting/ A Client Server Failed to Access a File System
Updated on 2025-11-07 GMT+08:00
Symptom
Access from a client server to a file system was denied. All services on the server were abnormal.
Possible Causes
  • Cause 1: The file system is abnormal.
  • Cause 2: The file system fails to be mounted to the server after being forcibly unmounted.
Fault Diagnosis
Take troubleshooting measures based on possible causes.
Solution
    Log in to the management console. On the Scalable File System page, check whether the file system is in the Available state.
    • If yes, go to Cause 2.
    • If no, see File System Is Abnormal to restore the file system to the available state, and then access the file system again.
    1. This problem is caused by a defect of servers. Restart the server to resolve this problem.
    2. Check whether the file system can be properly mounted and accessed from the server.
      • If yes, no further action is required.
      • If no, contact technical support.
