- What's New
- Function Overview
Billing
- Billing Overview
- Billing Modes
- Billed Items
- Billing Examples
- Billing Mode Changes
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQ
- How Do I Purchase SFS?
- How Do I Renew the Service?
- How Do I Check Whether the Subscriber Is in Arrears?
- Can I Purchase SFS Capacity-Oriented Resource Packages When I Still Have Valid Ones in Use?
- How Do I Check the Usage of an SFS Capacity-Oriented Resource Package?
- How Do I Adjust the Size of an SFS Capacity-Oriented Resource Package?
- Do SFS Capacity-Oriented and SFS Turbo Share One Resource Package?
- Getting Started
- User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Calling General Purpose File System APIs
- Getting Started (SFS Capacity-Oriented)
- Getting Started with SFS Turbo
- Getting Started with General Purpose File System
SFS Capacity-Oriented APIs
- API Version Queries
- File Systems
- File System Access Rules
- Quota Management
- Expansion and Shrinking
Tag Management
- Adding a Tag to a Shared File System
- Deleting a Tag from a Shared File System
- Querying Tags of a Shared File System
- Querying Tags of All File Systems of a Tenant
- Batch Adding Tags to a Shared File System
- Batch Deleting Tags from a Shared File System
- Querying Shared File Systems by Tag
- Querying the Number of Shared File Systems by Tag
- AZ
SFS Turbo APIs
- Lifecycle Management
- Connection Management
- Tag Management
- Name Management
- File System Management
Storage Interworking Management
- Adding a Backend Target
- Querying Backend Targets
- Obtaining Details About a Backend Target
- Deleting a Backend Target
- Updating the Properties of a Storage Backend
- Updating the Auto Synchronization Policy of a Storage Backend
- Creating an Import or Export Task
- Querying Details About an Import or Export Task
- Listing Import and Export Tasks
- Deleting an Import or Export Task
- Updating a File System
- Directory Management
Permissions Management
- Creating a Permission Rule
- Querying Permission Rules of a File System
- Querying a Permission Rule of a File System
- Modifying a Permission Rule
- Deleting a Permissions Rule
- Creating and Binding the LDAP Configuration
- Querying the LDAP Configuration
- Modifying the LDAP Configuration
- Deleting the LDAP Configuration
- Task Management
- General Purpose File System APIs
- Common Parameters
- Appendix
- SDK Reference
Troubleshooting
- Mounting a File System Times Out
- Mounting a File System Fails
- File System Performance Is Poor
- Failed to Create an SFS Turbo File System
- A File System Is Automatically Disconnected from the Server
- A Server Fails to Access a File System
- The File System Is Abnormal
- Data Fails to Be Written into a File System Mounted to ECSs Running Different Types of Operating Systems
- Failed to Mount an NFS File System to a Windows IIS Server
- Writing to a File System Fails
- Error Message "wrong fs type, bad option" Is Displayed During File System Mounting
- Failed to Access the Shared Folder in Windows
- Concepts
- Specifications
- Restrictions
- Networks
Billing
- How Do I Access a File System from a Server?
- How Do I Check Whether a File System on a Linux Server Is Available?
- What Resources Does SFS Occupy?
- Why Is the Capacity Displayed as 10P After I Mount My SFS Capacity-Oriented File System?
- Why the Capacity Is Displayed as 250TB After I Mount My General Purpose File System?
- How Can I Migrate Data Between SFS and OBS?
- Can a File System Be Accessed Across Multiple AZs?
- Can I Upgrade an SFS Capacity-Oriented File System to an SFS Turbo File System?
- Can I Upgrade an SFS Turbo File System from Standard to Standard-Enhanced?
- How Can I Migrate Data Between SFS and EVS?
- Can I Directly Access SFS from On-premises Devices?
- How Do I Delete .nfs Files?
- Why My File System Used Space Increases After I Migrate from SFS Capacity-Oriented to SFS Turbo?
- How Can I Improve the Copy and Delete Efficiency with an SFS Turbo File System?
- How Do Second- and Third-level Directory Permissions of an SFS Turbo File System Be Inherited?
- How Do I Deploy SFS Turbo on CCE?
- Videos
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Introduction
- Getting Started
- Management
- Typical Applications
Troubleshooting
- Concepts
- Specifications
- Restrictions
- Networks
- Other Operations
- Change History
- API Reference (Paris Region)
- User Guide (Kuala Lumpur Region)
- API Reference (Kuala Lumpur Region)
- Glossary
Auditing
Cloud Trace Service (CTS) records operations of SFS resources, facilitating query, audit, and backtracking.
Operations
Operation |
Resource Type |
Trace |
Creating a shared file system |
sfs |
createShare |
Modifying a shared file system |
sfs |
updateShareInfo |
Deleting a shared file system |
sfs |
deleteShare |
Adding a share access rule |
sfs |
addShareACL |
Deleting a share access rule |
sfs |
deleteShareACL |
Querying Traces
- Click
in the upper left corner and select a region and project.
- Choose Management & Deployment > Cloud Trace Service. The Cloud Trace Service page is displayed.
- In the navigation pane on the left, choose Trace List.
- On the trace list page, set Trace Source, Resource Type, and Search By, and click Query to query the specified traces.
For details about other operations, see section "Querying Real-Time Traces" in the Cloud Trace Service User Guide.
Disabling or Enabling a Tracker
This section describes how to disable an existing tracker on the CTS console. After the tracker is disabled, the system will stop recording operations, but you can still view existing operation records.
- Click Trackers in the left pane.
- Click Disable on the right of the tracker information.
- Click Yes.
- After the tracker is disabled, the available operation changes from Disable to Enable. To enable the tracker again, click Enable and then click Yes. The system will start recording operations again.
