SFS and Other Services
Relationships Between SFS and Other Services
Function |
Related Service |
Reference |
A file system and the servers must belong to the same project so that they can mount the same file system for data sharing. |
Elastic Cloud Server (ECS) |
Mounting an NFS File System to ECSs (Linux) Mounting an NFS File System to ECSs (Windows) |
VPC allows you to provision isolated virtual networks defined and managed by yourself. This improves the security of cloud resources and simplifies network deployment. A server cannot access file systems in a different VPC. Before using SFS, assign the file system and the servers to the same VPC. |
Virtual Private Cloud (VPC) |
Creating a File System |
IAM is an enterprise-level self-help cloud resource management system. It provides user identity management and access control functions. When an enterprise needs to provide SFS for multiple users within the enterprise, the enterprise administrator can use IAM to create users and control these users' permissions on enterprise resources. |
Identity and Access Management (IAM) |
Once you have subscribed to SFS, you can monitor its performance, such as the read bandwidth, write bandwidth, and read and write bandwidth on Cloud Eye, which does not require any plug-ins. |
Cloud Eye |
Cloud Trace Service (CTS) allows you to collect, store, and query cloud resource operation records and use these records for security analysis, compliance auditing, resource tracking, and fault locating. With CTS, you can record operations associated with SFS for later query, audit, and backtrack operations. |
Cloud Trace Service (CTS) |
