- What's New
- Function Overview
Billing
- Billing Overview
- Billing Modes
- Billed Items
- Billing Examples
- Billing Mode Changes
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQ
- How Do I Purchase SFS?
- How Do I Renew the Service?
- How Do I Check Whether the Subscriber Is in Arrears?
- Can I Purchase SFS Capacity-Oriented Resource Packages When I Still Have Valid Ones in Use?
- How Do I Check the Usage of an SFS Capacity-Oriented Resource Package?
- How Do I Adjust the Size of an SFS Capacity-Oriented Resource Package?
- Do SFS Capacity-Oriented and SFS Turbo Share One Resource Package?
- Getting Started
- User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Calling General Purpose File System APIs
- Getting Started (SFS Capacity-Oriented)
- Getting Started with SFS Turbo
- Getting Started with General Purpose File System
SFS Capacity-Oriented APIs
- API Version Queries
- File Systems
- File System Access Rules
- Quota Management
- Expansion and Shrinking
Tag Management
- Adding a Tag to a Shared File System
- Deleting a Tag from a Shared File System
- Querying Tags of a Shared File System
- Querying Tags of All File Systems of a Tenant
- Batch Adding Tags to a Shared File System
- Batch Deleting Tags from a Shared File System
- Querying Shared File Systems by Tag
- Querying the Number of Shared File Systems by Tag
- AZ
SFS Turbo APIs
- Lifecycle Management
- Connection Management
- Tag Management
- Name Management
- File System Management
Storage Interworking Management
- Adding a Backend Target
- Querying Backend Targets
- Obtaining Details About a Backend Target
- Deleting a Backend Target
- Updating the Properties of a Storage Backend
- Updating the Auto Synchronization Policy of a Storage Backend
- Creating an Import or Export Task
- Querying Details About an Import or Export Task
- Listing Import and Export Tasks
- Deleting an Import or Export Task
- Updating a File System
- Directory Management
Permissions Management
- Creating a Permission Rule
- Querying Permission Rules of a File System
- Querying a Permission Rule of a File System
- Modifying a Permission Rule
- Deleting a Permissions Rule
- Creating and Binding the LDAP Configuration
- Querying the LDAP Configuration
- Modifying the LDAP Configuration
- Deleting the LDAP Configuration
- Task Management
- General Purpose File System APIs
- Common Parameters
- Appendix
- SDK Reference
Troubleshooting
- Mounting a File System Times Out
- Mounting a File System Fails
- File System Performance Is Poor
- Failed to Create an SFS Turbo File System
- A File System Is Automatically Disconnected from the Server
- A Server Fails to Access a File System
- The File System Is Abnormal
- Data Fails to Be Written into a File System Mounted to ECSs Running Different Types of Operating Systems
- Failed to Mount an NFS File System to a Windows IIS Server
- Writing to a File System Fails
- Error Message "wrong fs type, bad option" Is Displayed During File System Mounting
- Failed to Access the Shared Folder in Windows
- Concepts
- Specifications
- Restrictions
- Networks
Billing
- How Do I Access a File System from a Server?
- How Do I Check Whether a File System on a Linux Server Is Available?
- What Resources Does SFS Occupy?
- Why Is the Capacity Displayed as 10P After I Mount My SFS Capacity-Oriented File System?
- Why the Capacity Is Displayed as 250TB After I Mount My General Purpose File System?
- How Can I Migrate Data Between SFS and OBS?
- Can a File System Be Accessed Across Multiple AZs?
- Can I Upgrade an SFS Capacity-Oriented File System to an SFS Turbo File System?
- Can I Upgrade an SFS Turbo File System from Standard to Standard-Enhanced?
- How Can I Migrate Data Between SFS and EVS?
- Can I Directly Access SFS from On-premises Devices?
- How Do I Delete .nfs Files?
- Why My File System Used Space Increases After I Migrate from SFS Capacity-Oriented to SFS Turbo?
- How Can I Improve the Copy and Delete Efficiency with an SFS Turbo File System?
- How Do Second- and Third-level Directory Permissions of an SFS Turbo File System Be Inherited?
- How Do I Deploy SFS Turbo on CCE?
- Videos
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Introduction
- Getting Started
- Management
- Typical Applications
Troubleshooting
- Concepts
- Specifications
- Restrictions
- Networks
- Other Operations
- Change History
- API Reference (Paris Region)
- User Guide (Kuala Lumpur Region)
- API Reference (Kuala Lumpur Region)
- Glossary
Show all
Mounting an NFS File System to ECSs
After creating a file system, you need to mount the file system to ECSs so that ECSs can share the file system.
- You have checked the type of the operating system on each ECS. Different operating systems use different commands to install the NFS client.
- You have created a file system and have obtained the mount point of the file system.
- At least one ECS that belongs to the same VPC as the file system exists.
- Log in to the management console using a cloud account.
- Log in to the management console and select a region and a project.
- Under Computing, click Elastic Cloud Server to switch to the ECS console.
- Log in to the ECS as user root.
If you log in to the ECS as a non-root user, see Mounting a File System to an ECS Running Linux as a Non-root User.
- Install the NFS client.
- Run the following command to check whether the NFS software package is installed.
- On CentOS, Red Hat, Oracle Enterprise Linux, SUSE, EulerOS, Fedora, or OpenSUSE:
- On Debian or Ubuntu:
If nothing is displayed, go to 3.b.- On CentOS, Red Hat, EulerOS, Fedora, or Oracle Enterprise Linux:
libnfsidmap nfs-utils
- On SUSE or OpenSUSE:
nfsidmap nfs-client
nfs-common
- Run the following command to install the NFS software package.
The following commands require that ECSs be connected to the Internet. Otherwise, the installation will fail.
- Run the following command to create a local path for mounting the file system:
mkdir Local path
- Run the following command to mount the file system to the ECS that belongs to the same VPC as the file system. Currently, the file system can be mounted to the ECS running Linux using NFS v3 only.
Table 1 describes the variables.
mount -t nfs -o vers=3,timeo=600,noresvport,nolock Mount point Local path
NOTICE:
After an ECS where file systems have been mounted restarts, it loses the file system mount information. You can configure automatic mount in the fstab file to ensure that an ECS automatically mounts file systems when it restarts. For details, see Mounting a File System Automatically.
Table 1 Parameter description Parameter
vers
File system version. Currently, only NFSv3 is supported, so the value is fixed to 3.
timeo
Waiting time before the NFS client retransmits a request. The unit is 0.1 second. The recommended value is 600.
resvport/noresvport
Whether the confidential source port is used for server connection. By default, resvport indicates that the confidential port is used, and noresvport indicates that the confidential port is not used. The kernel version is 2.6.28 or later.
You are advised to set this parameter to noresvport so that a new TCP port can be used when the network is reconnected. This ensures that the connection is not interrupted when the network recovers from a fault.
lock/nolock
Whether to lock files on the server using the NLM protocol. If nolock is selected, the lock is valid for applications on one host. For applications on another host, the lock is invalid. The recommended value is nolock. If this parameter is not specified, lock is selected by default. In this case, other servers cannot write data to the file system.
Mount point
The format for an SFS Turbo file system is File system IP address:/, for example, 192.168.0.0:/. See Figure 1.
Local path
Local path on the ECS, used to mount the file system, for example, /local_path.
For more mounting parameters for performance optimization during file system mounting, see Table 2. Use commas (,) to separate parameters. The following command is an example:
mount -t nfs -o vers=3,timeo=600,nolock,rsize=1048576,wsize=1048576,hard,retrans=3,noresvport,async,noatime,nodiratime Mount point Local path
Table 2 Parameters for file system mounting Parameter
rsize
Maximum number of bytes that can be read from the server each time. The actual data is less than or equal to the value of this parameter. The value of rsize must be a positive integer that is a multiple of 1024. If the entered value is smaller than 1024, the value is automatically set to 4096. If the entered value is greater than 1048576, the value is automatically set to 1048576. By default, the setting is performed after the negotiation between the server and the client.
You are advised to set this parameter to the maximum value 1048576.
wsize
Maximum number of bytes that can be written to the server each time. The actual data is less than or equal to the value of this parameter. The value of wsize must be a positive integer that is a multiple of 1024. If the entered value is smaller than 1024, the value is automatically set to 4096. If the entered value is greater than 1048576, the value is automatically set to 1048576. By default, the setting is performed after the negotiation between the server and the client.
soft/hard
soft indicates that a file system is mounted in soft mount mode. In this mode, if an NFS request times out, the client returns an error to the invoking program. hard indicates that a file system is mounted in hard mount mode. In this mode, if the NFS request times out, the client continues to request until the request is successful.
The default value is hard.
retrans
Number of retransmission times before the client returns an error. The default value is 3.
resvport/noresvport
sync/async
sync indicates that data is written to the server immediately. async indicates that data is first written to the cache before being written to the server.
Synchronous write requires that an NFS server returns a success message only after all data is written to the server, which brings long latency. The recommended value is async.
noatime
If you do not need to record the file access time, set this parameter. This prevents overheads caused by access time modification during frequent access.
nodiratime
If you do not need to record the directory access time, set this parameter. This prevents overheads caused by access time modification during frequent access.
You are advised to use the default values for the parameters without use recommendations.
- Run the following command to view the mounted file system:
mount -l
If the command output contains the following information, the file system is mounted successfully.Mount point on /local_path type nfs (rw,vers=3,timeo=600,nolock,addr=)
- After the file system is mounted successfully, access the file system on the ECSs to read or write data.
If the mounting fails or times out, rectify the fault by referring to Troubleshooting.
The supported maximum size of a file to be written is 16 TB.
